Question about Oregon Scientific RGR126 Rain Gauge with Outdoor Thermometer and 9day Memo
Does not show rain amount
Stopped showing rain amount
Rainbird sprinkler manuals
The top of the head has a diagram that shows the pattern and the amount of water flow.
Sep 07, 2014 | Rainbird Rain Bird 5000S-PLPC-NP Part Cir....
I got a call saying I had won a rain mate at the home and garden show are they going to come to my home for their presentation and try and sell me stuff?
they will if you did not enter into it, if you did and it was a free entry then they will try to sell you stuff if you payed a small amount then they are not allowd to sell you stuff as payment has allready been made.
Mar 13, 2014 | Rainbow Air Purifiers
Oregon scientific manuals
I think there is a problem with the device chip. You need to show it to the technician.
Jul 22, 2013 | Oregon Scientific Wireless rain gauge w/...
Rainbird RC-Bi timer issue
Copy following link to identify sprinkler & irrigation timers on market, and buy another one.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Install heavy-duty mechanical timer.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Replace sprinkler head
Check that voltage is at least 80% amount that shows on rating plate of timer. ie: 80% x 125V = 100Volts
Jun 29, 2013 | Rain Bird Hardware & Accessories
Where can I buy plus size rain jackets?
There are several plus size websites that sell rain jackets and other rain gear. Check out this link that shows you a number of places selling rain gear;
http://www.nextag.com/womens-plus-size-rain-jacket/products-html
Jan 14, 2013 | Clothing
1999 Suburban 5.7L Misfires when it rains.
Did you change the plug wires?A good way to find an ignition problem is to take a spray bottle with water and spray your engine.This will show up bad wires or ignition arcing in the dark.Try spraying the coil also.Hope this helps.Good luck.
Dec 05, 2011 | 1999 GMC Suburban
I have a 2005 Chevy Silverado whose driver side seat warmer goes on by itself. It may cycle through all of the settings and turn off but usually will immediately turn itself on again. No amount of manual...
May be a slight short in the switch/button. Enough that it cycles the settings or just stays on. If you want it to stay off for now, look for a fuse or relay to pull. Come to think of it, might be a bad relay. If there is one for each seat, try swapping them out and see if the problem starts on the other seat. If it follows the relay, then there's your problem.
Apr 28, 2017 | 2005 Chevrolet Silverado
The chair was outside and got a small amount of rain on it. Now when we turn it on, the lights (that show battery charge) blink fast and it will not move. My dad is grounded until we can figure this out....
Hi. Count how many lights are flashing, it is showing a fault code. Let us know, or contact your local dealer. Check that the free-wheel levers are in the correct place. Good luck. Neil.
May 19, 2010 | Pride Jazzy 1103 Ultra Standard Power...
2005 LeSabre, with climate control. The A/C and Heat seem to work fine. However, the fan stop working yesterday. The display on the climate control panel shows the fan to be operating at max (led shows 4...
your owners manual will identify the fuse to check. If you don't have the manual, you can get one online at gm. If the fuse is good, check the blower connection for water/corrosion. If connector looks good, check it for voltage from the switch. If voltage is getting to the motor, replace the motor.
May 18, 2017 | 2005 Buick LeSabre
Red warning light shows up
It is because of weather when the weather is not clear or it gets rain the device is unable to catch the signal that's why it get red. :)
*Cheers*
Dec 15, 2009 | Alvarion Wireless Access Point
Oregon Scientific RGR126 Rain Gauge with Outdoor Thermometer and 9day Memo Logo
37 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Timllfixit
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
