Question about Adesso Square Floor Lamp with Paper Shade and Shelves - Black/ Beige
The chord that you pull to turn the light on on the "Square Floor Lamp With Paper Shade And Shelves - Black" I accidently pulled out from pulling it too hard or the wrong way. How can I fix it?
*Detached Light Chord (chord still intact even though not connected to lamp)
    Problem Solver:
  • 7 Answers
Before anything ***UNPLUG UNIT FROM WALL***
Some lighting fixtures you can take apart, others you cannot. Turn the item upside down so you can see the lighting fixture. If you see that it has a few screws you can take it apart and replace the cord.
If not, take out the lighting fixture (one or two screws at the maximum) and go to Hobby Lobby or Michael's...something like these. They will have a similar product you can replace it with. It might not be te same, but if it is close then you should be able to affix it in your unit.
Posted on May 10, 2013
Check paper light is blinking. No paper jam exists, have cleaned rollers but printer will not grab paper. Have tried replacing with fresh paper but no result. Will not print test page, gives same error.
Paper jams can occur for a variety of reasons but are usually paper related. Follow the steps below to clear the paper jam:
1) Turn off the all-in-one and unplug the power cord. With the power off, the paper feed rollers will turn.
2) Open the rear access door of the all-in-one by pressing in on the left side of the access door and then pulling it toward you.
NOTE: All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems.
3) From the rear access door opening, gently pull the jammed paper free.
4) Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
Do not continue to push the paper in after some resistance is felt. If the paper is pushed in too far, more than one page will feed into the all-in-one at a time.
5) Reattach the rear access door by inserting the two pins on the right of the door into the holes for them and then pressing in gently but firmly on the left side.
6) Reconnect the power cord to the unit and turn the unit on.
7) if it does not work ... clean the rollers from the rear door of the printer
8) try different wall outlets..
9) then do a power drain by unplugging the power chord from the back of the printer. press and hold the power button for 30 sec and then replug the power chord.
10)if issue does not get resolved service the product
Mar 26, 2011 | HP PSC 1401 All-In-One Printer
I have a 2003 Chevy Astro Van and my Daytime Running Lamps not working. Any ideas? I also have problems with my locks. I know it's the actuators, but how do I replace them when they are riveted in? SN: I...
as far as daytime running lights, pull emergency brake handle, lift up on the ebrake pedal while you have handle pulled back. not come on? open hood look for square black box marked main fuses and or relays. lift cover up on box, turn the lid over and look for location marked on inside of lid for location of daytime running lights[fuse] check that fuse to see if its blown. to check bad fuse, look at fuse inside the colored square for a silver S if that S has a break in it where it will not make a complete S the fuse is blown. please repost your question about your locks thank you for choosing fixya.com
Dec 27, 2010 | 2002 Chevrolet Astro
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Lamp replacement
Sure, I do by myself. Seat on the floor in front of the TV
!st. step: Grasp both side of the silver front cover with your
fingertips and pull it from projection display.
Then remove it.
2nd. At your left hand you can see a black knob. Turn the
open/lock knob to the left. Pull the black unit that have
the lamp inside. Cover out and down to open.
3rd. Loosen the lamp (black unit) screw with screwdriver.
Grasp the handle of the black unit lamp and slowly
remove the unit.
4th. Insert the new lamp black unit being careful. Tighten the
black unit lamp screw with a screwdriver.
5th. Close the lamp cover. Turn the lock/open knob to the
right.
6th. Replace the silver front cover. Finished.
R. Vega from Puero Rico
Apr 28, 2009 | Panasonic PT-52LCX65 44" HDTV
Paper jam how to remove paper when jamed in rollers
First unplug the printer from power chord.
  1. Open the upper front door.
2. Grasping the print cartridge by the hand grip, pull it towards you and slightly up to lift it out of the holder.
3. Then pull the cartridge straight out towards you.
4. Locate the feed roller release lever and gently push it back to release the pressure on the paper.
5. Pull the paper out.
Hope this helps .
Feb 22, 2009 | Lexmark X4650 InkJet Printer
How to access brake tail light to change
Tail light replacement is not as hard as it seems.
Tools needed:flat head screwdriver and a deep 5/32 socket(a pair of pliers will work).
Step 1: open trunk and pull back truck liner at tail light.There is a small button clip on liner.Use screwdriver to pop up the center of button clip,pull clip out of hole.
Step 2:You will see a black wire attached to the body of car with 2 white clips.Use screwdriver to pop clips off of studs.
Step 3:Remove the nuts from the studs and pull tail light assembly straight back away from car.The outer side of the light just snaps in and out of place.
Step 4:Turn light socket counter clockwise 1/3 turn and pull out.
Step 5:Pull bad bulb straight out and replace.Reverse steps to reassemble.
Oct 24, 2008 | 2007 Nissan Sentra 2.0 SL Sedan
Pulled the chord while the lamp was on. HP vp6310 does not light upanymore
One of the transistor on the power supply is blown. I can repace it.
Dec 07, 2007 | HP VP6310 Multimedia Projector
Adesso Square Floor Lamp with Paper Shade and Shelves - Black/ Beige Logo
130 people viewed this question
Top Adesso Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Adesso Furniture Expert? Answer questions, earn points and help others
