Question about Craftsman 24 Hp 48" Deck Yard Tractor
Mower backfires and loss of power
Using my mower to blow leaves to side of driveway. started backfiring and seemed tp be running at almost half power. changed plugs/oil/air filter. started it back up and it still does same. do i need new engine
or what. mower is about 5 years old. can the problem be with carb.
24 hp b&S engine craftsman
  • Anonymous Mar 18, 2014
    backfiring back fireing
    back fires backfires
    Novelist:
  • 126 Answers
I would also check fuel flow. pull the gas line from the carb and see if gas flows out at a good rate (into a metal can of course) or if it trickles out. if the latter, then gas tank either has junk at the bottom preventing the gas from flowing or the vent hole (usually on the gas cap) is plugged.
i have also had my carb float bowl rust out on me, but that took 10 years.
Posted on Jan 29, 2009
    Problem Solver:
Install carb kit, they are very fussy when it comes to fuel flow..
Posted on Jan 21, 2009
My craftman 20hp bs engine backfires and has loss of power since i rinsedthe engine off i have changed the plugs and air filter so far ?
Hi, I would be inclined to use a compressor to give the whole engine a good blow through to get rid of any water that is hanging around after your rinse off, sounds like a plug is not getting a spark when it should and hence the backfire and loss of power. Hope this helps.
Steve
Nov 15, 2013 | Garden
My husband bought a 2011 Husqvarna YTH2348. I am the one that mows the grass. We had the mower serviced last week. We have a HUGE lawn and I mowed all but the orchard. The next day, I went out to finish...
Black smoke is generally indicative of a rich fuel system. whitish blue smoke is generally burning oil.
It sounds like there is something wrong with the fuel metering at full throttle. You might check that the mechanical compression release isn't coming on when you go to full throttle.
Aug 17, 2013 | Husqvarna Garden
New craftsman mower has rough idle backfires and has loss of power
It sounds like the valves are out of adjustment.
Apr 07, 2013 | Craftsman Garden
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
My lt 1000 17.5 hp riding mower will backfire once in awhile when starting but runs fine once it starts. why
first smell the oil is there a gas smell to it?the needle valve maybe dripping fuel and over flowing into the intake
Apr 18, 2012 | Craftsman Garden
Enigne backfires after I turn the mower off
Probably, but need more info. How old is the mower? Was it fixed or tampered with recently? is it a "cared for" mower? (Not left outside in the rain and snow...etc...) Backfires can have a few causes. Too much fuel, way too lean of a fuel mixture, (Not enough or wrong type of oil or mix ratio) Misadjusted mixture screws on carb, idle set too fast/high, generally it is a adjustment issue though. Try a tune up! Ya small engines need them more often than you'd think! And there is one more culprit for the loss of power you mentioned,and it may or may not be causing the backfires but you never know...and that is the mower blade's "sheer pin" or "Breakable keyway key" If (with the mower off) you reach the blade and try to spin it in both directions and it seems to move out of sync with the engine crankshaft (or wiggles a bit too freely) Than you need to replace the split /broken key with a new one. I had a Craftsman do that to me once and all the power returned like magic after replacing it. BE Careful! Its an easy fix if that is it, but you have to give more info.
May 09, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Rough runnig , backfiring when hot, no power
this may seem funny but, are you sure the fuel tank cap vent is working? It sounds like the engine is not getting proper supply of fuel, that's why it kinda runs with choke on
Apr 29, 2009 | Garden
Sudden loss of power, Backfiring, starts then stalls
Your timing belt could be broken. You want to have this checked as soon as possible to prevent any further engine problems.
Nov 27, 2008 | 1991 Honda Civic
Craftsman 24 Hp 48" Deck Yard Tractor Logo
978 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
