Question about Panasonic PT-AX200U Projector
I have a pansonic pt-ax220u, When I start it up it turns on perfectly fine and runs for about 2 minutes. After that the screen shuts off but the projector is still on.... Instead of the light being green or red it shows as a orange/yellowish light that stays steady. Not sure what this is......
  • 93 Answers
The main board of the projector needs replacement! not worth getting it replaced as it would cost very high! look out for a old working board that would cost lower!
Posted on Jan 18, 2013
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
SOURCE: Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Posted on Feb 08, 2009
  • 3 Answers
SOURCE: Projector shutting down after 2 mins.
this thread and video tells you how to fix it simply
http://www.avsforum.com/avs-vb/showthread.php?t=762444&page=23
http://www.youtube.com/watch?v=6jGwB05_gdk
Posted on May 01, 2009
SOURCE: My PT-AX100u will not turn on.
My PT-AX200U does the exact same thing. I installed a new lamp it worked great for the first week or two. Now and then when I want to turn it on, the green light blinks then the yellow light comes on and blinks and then it shuts itself off.
Posted on Dec 27, 2009
SOURCE: Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Posted on May 03, 2010
My vehicles shuts off after 3 three minutes of use or when its idling after first initial start but starts perfect when the engine is heated up. Can you help me with this problem?
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Engine turns over fine and starts, but stops in a second or 2. ... Good fuel pressure, starts, runs for about 7 seconds, dies after a sudden drop in fuel pressure. ...starts 15 minutes later, runs fine then stumbles and dies again 3 answers ... I drove carhome shut off and next morning would not start, but will turn ...
94 camry le 4cylinder starts when cold, shuts off .
Nov 23, 2015 | Cars & Trucks
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
The screen goes black. On every channel. Sound is perfect. Is the TV dead
Ok---let me describe something and you tell me if your case: Set comes on and has audio--after 2-5 minutes if you look closely at the screen do you see a odd and faint band of noise top to bottom and to the right of the center of the screen?
It takes a couple minutes and will be faint and easy to miss.
Let me know what you see.
Apr 24, 2012 | Panasonic PT-47WX49 47" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Panasonic PT-AX200U Projector Logo
272 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
