Question about HP Officejet Pro L7590 All-in-One InkJet Printer
Black does not print out correctly
The page comes out smeary looking and very sparse. It looks like someone dragged the ink across the page lightly. I have checked all the heads and run the tests in the manual but I can not seem to fix the problem. On the test page the yellow and fushia seem fine. There is no cobalt color and the black is very streaky...like the print jobs I have tried.
    Scholar:
  • 97 Answers
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to
printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and
then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Posted on Jan 29, 2009
Black page streaks
Hi
first check toner cartridge, if you have another test and if the problem is continuing fuser unit and will have to clean or replace it with another.
Feb 03, 2014 | Canon imageCLASS D1150 All-In-One Laser...
Photos are light with fine grainy appearance. Have tried the corrections in the manual without correction.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
Jul 21, 2011 | Lexmark X3470 All-In-One InkJet Printer
White lines across print
If you lay the print on the exit tray face up and open the cover. Look on the encoder strip, the clear plastic strip behind the carriage, you should see an ink or grease spot right above where the bad spot on the page is. Wipe the encoder strip with Q-tip or wiper with alcohol. Prints should look better.
Jan 08, 2010 | HP OfficeJet Pro k550 Printer
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
I just changed the cyan cartridge on my HP3700 LASERJET COLOUR PRINTER. I believe it was defective...as my print jobs are now coming out with three streeks on one side as though something is being dragged...
Please ignore this request, as I have found a local repair shop to take a look at it.
I will keep you on file, if I have any other trouble shooting needs.
Thanks for checking.
Sep 11, 2008 | HP Office Equipment & Supplies
INK LEAKAGE ON PRINTS
I need more specific info. Where is the ink: on one side only or all across the page. On the top only or all down the page. Does it look like smudges or spatter.
Aug 17, 2008 | Office Equipment & Supplies
Left & right streaks when printing
Hi, it sounds that your printer may require service to clean the printhead thourouly.
Tirzo
May 09, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Cannon multipass 390 print problems
I have the exact same problem, cleaned heads, replaced cartridge, nothing prints, no ink at all no colors or black.
May 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
77 people viewed this question
Ben Johnson
