Question about Procom ML300EBC Heater
Heater runs for appox 2-4 minutes and then shuts down..
Seems like when the blower comes on it shuts down quicker.. Turned off the blower and then it runs for a longer period, but still shuts down..
I have it going thru 1/2 flex pipe that was recommended by the HVAC and Plumbing installers..
I saw the Thermocouple response, could that be it here too ???
  • ronald_b_kel Jan 22, 2009
    It is Natural Gas..
    Procom ML300EBC Heater - Natural Gas
    New Friend:
  • 70 Answers
What kind of furnace do you have? Is it electronic or standing pilot? If you have electronic then it could be flame sensor if you have standing pilot and the pilot goes out and you have to relight then it is probably the thermocouple what is going through an 1/2 flex pipe explain this a little more. Have you checked filter.
Posted on Jan 22, 2009
1994 chevy kodiak with Cat 3116. Heater/AC blower shuts down
you should make a diagnostic to know what happened to your car
of course you need an auto diagnostic tool : http://www.chinasnoy.comand you can find all kinds of tools in
May 21, 2013 | Cars & Trucks
Jandy LX250-L Burner shuts down and no errors
It is more likely the board on the LX.
If you have a volt meter check the IND connection on the Fenwal for 24volts while running and keep your meter on it until it shuts down. If the power is still present at the IND while shutting down then it would appear to be a Fenwal problem. It sounds like the temp circuit on the board or the temp sensor it self is bad. Try dipping the temp sensor in a glass of water with a confirmed temp to see if it is accurate.
Apr 03, 2017 | Pool & Spa
I have a builder installed Goodman GDS80904BHA that is approximately 5 years old. Recently, when the furnace completes a heat cycle, approximately 1-2 minutes after the cycle has completed and after the...
I would guess that the fan off setting on your limit is set a little to high. If you have the manual you can see what it says about changing the running time for the fan after the burner has shut off look on the control board and you should see two switches,one to set the time for burners to fire before main blower starts and one to set time for fan to run after burners shut off. To help with the problem you are describing set fan run time up so fan wii run longer. Hope this helps. Thaks.
Nov 22, 2010 | Goodman GDS80904BNA Open Flame Heater
Heating up, shuts off, Shutting off going about an 1 hour trip. hearing small noise in front of engine. Seams to be running hot. service techs put it on dyna but no results. Shut off again next trip. ran...
Had a simuliar problem, Bike would have a total shutdown a High Temps/Low Speeds/High RPMs. Everything would reset itself after appox 2 minutes. Everything would shutdown Electric and engine.
2 Harley dealers spent 75 hours diagnosing it, dealer could not reproduce it. Last repair was to replace battery cables. Seems to have fixed it. Have ridden 15oo miles since repair. Problem reacurred once last time I rode. Again complete shutdown bike restored after 2 minutes. Did not happen again the rest of the day over 200 miles
Aug 30, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Goodman GMT070-3A heater. When heater is turned
look for flashing code thru blower door peep hole aftter it shuts down and let me know the amount of flashes
Dec 03, 2009 | Heating & Cooling
Blower will run for appox. three minutes then just quit. i can most of the time start it back up but it stop as be for. if i let it itle for a little wait it will work but goes back like before. HELP!!!!!
it could be the mixture is two lean or it could be a coil going out iy grts hot then shuts down till it cools or the mixture is lean and also gets hot or it could aslo be a clogged exhaust will loose power and quit it will idle but not rev like it should
Nov 03, 2009 | Garden
have service completed
Oct 24, 2008 | Rheem Water Heaters
Heat turns off
Sounds like the high limit switch on the heater is kicking off. The flash is the switch shutting off the heating element. The only way to reset it is to turn unit off for about 5 minutes. Possible problems are: 1.) Bad thermostat 2.) blower motor not turning fast enough which means motor is bad.
Oct 06, 2007 | Dimplex DS5598 Mid-Size Heater
Procom ML300EBC Heater Logo
384 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
