Question about HP Photosmart 3310 Printer
My machine won't let me receive a fax because my red/magenta cartridge is out. Can't I receive a black and white fax without that cartridge in? How?
    Genius:
  • 2,120 Answers
No, sorry
Posted on Jan 21, 2009
When I receive a fax it comed back blurred
Check print out from system, if its good printer is good, you can suspect other side fax machine..Generally most of the fax machines are "Thermal Technology" black & white scaled machines, this technology is old, we can't expect that much quality print outs..
Jun 13, 2012 | HP 640 Inkjet Fax Machine
MY HP FAXNUMER 640 WON'T RECEIVE FAXS AFTER I REPLACED TONER CARTRIDGE
The two aren`t related, you must have pressed a button that changed the `reception mode` to Manual from either `auto` or `tad`
Apr 04, 2012 | HP 640 Inkjet Fax Machine
HP Color Laser Jet CP1215: won't print at all since magenta is out. I changed printer to grayscale but just keeps blinking the magenta sing and the traiangle with ! sign next to it
I know the frustration being in IT for over 20 years working on various peripherals.
These printer MIX so that way there is a balance at the final phase. You have to purchase a magenta cartridge to get this working again. Bypassing this will make tis printer suffer and long term damage can cause a economical issue on your end in the long run.
Now if your at a critical point you can bypass but I do not professionally recommend this but here it goes.
1. Open the CP1210 Series Toolbox 2. OPEN System Settings 3. Then enable Cartridge Out Override 4. Then click apply
I hope this works for you, whilst you purchase a magenta toner. Please do not forget to leave a positive rating and feedback.
Best of Luck
Rulds2008
Jul 26, 2011 | HP LaserJet CP1215 Color Printer
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
How do you print only in black & white to a dell 5110cn laser printer? the printer is currently out of magenta toner and will not print. do you need a magenta toner cartridge in order to print to this...
go into printer and faxes and and right click on your printer and and go to printer Prefereces you should see either print in black in white or gray scale
this should fix it for you
Good Luck
Happy Computing
Jan 09, 2010 | Dell 5110cn Laser Printer
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
Fax says to replace yellow cartridge...
There is a menu prompt that allows you to choose to print in black only.
Sep 16, 2008 | Office Equipment & Supplies
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Fax does not want to print
No the machine uses some of the colour ink when printing faxes, mostly cyan.
Apr 23, 2007 | Brother IntelliFAX 1940CN Plain Paper...
HP Photosmart 3310 Printer Logo
Seeker5211
Seeker5211
