Question about Samsung HCN653W 65" Rear Projection Television
DVI imput not working
I just bought playstation 3 and also the HDMI to DVI cable, and i had no picture. I set all the options correctly on the playstation, and i still did not have a picture. Any ideas?? Something i may have overlooked?? Or is the input just not working.
You know, I have to unplug the HDMI cable from my DVD player and then plug it back in after both TV and DVD player are turned on. Really strange. But that seems to do the trick. Let me know if that helps you at all.
Posted on Aug 01, 2007
Your tv is not 1080p use 720p
Posted on Jul 04, 2007
SOURCE:
Hitachi 51f510 sound no picture
select hdmi on menu or dvi/component on tv
Jul 05, 2013 | Hitachi 51F510 51" Rear Projection...
Setting up HDMI / DVI port as a selectable Imput
may i know the model and maker of the device you want to use a HDMI cable
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
All picture and no sound
Rick:
simply unplug--then replug--your HDMI cable. Or also go into the audio setup menu and reapply the "automatic" setting for HDMI to get the sound to work. I don't know if Sony can do anything about this or not in a firmware upgrade, but what it can do is try to simplify the labeling on some of the sound settings.
Let me know
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
I just bought a Playstation 3 for the first time. I have it hooked up through HDMI using an HDMI to DVI converter to my TV. It looks great, but there is no sound. Even hooking the optical sound output to...
On your PS3, go to the Settings tab, then scroll down to the "Sound Settings".
Once in Sound Settings, select "Audio Output Settings"
Here you should have 3 options: HDMI; Optical Digital; and Audio Input Connector
Choose Optical Digital
You should be all set.
Also, make sure after doing this your stereo is on the correct channel.
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
I have a Playstation 3/blu ray player and I don't know how to get hi def video on a samsung hln467w
Your TV only has a DVI input, not an HDMI which PS3 has as an output. You can buy a HDMI to DVI adapter and connect the HDMI out of the PS3 to the DVI input of the TV. To get the true HighDef video you need a HDMI input on the TV to enjoy the full capacity of the Blu ray capabilities of the PS3. DVI came out before the HDMI standard and your picture will look good but not like HDMI. I have the same problem with my samsung 65 inch. I Bought the wrong technology. I hope this helps and good luck!
Nov 07, 2009 | Samsung HLN467W 46" Rear Projection HDTV
DVI-HDMI not working with Sanyo Z2
HD comes as 720p and 1080p - the Sanyo will cope with 720 but not 1080 full HD - check the specs in the manual. You should have a DVD output setting for screen mode.
Sep 07, 2009 | Sanyo PLV-Z2 Multimedia Projector
Ps3a
I have had this problem once before and it was because my sound output was was set to the (yellow white red) and so what you have to do is go to Sound Settings then go to Audio Output Settings then what your going to choose is HDMI then it will ask for what method and just select Automatic, then you should be able to here sound threw your tv.
Oct 13, 2008 | Sony Playstation 3 (PS3) Console
Lcd to pc
YOU MUST GO INTO YOUR COMPUTER CONTROL PANEL TO SET THE DISPLAY SETTINGS FOR YOUR LCD.
Sep 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Hdmi to dvi
a DVI Connection does not transmit sound, so you will need a seperate audio cable. Have you changed the settings in the ps3 and your tv's input to HD signal or 720 DPI, do not choose 1080i or 1080P as DVI does not support those high settings.
Sep 05, 2007 | Sony Playstation 3 (PS3) Console
Samsung HCN653W 65" Rear Projection Television Logo
132 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
