Question about Frigidaire GLRT188WD Top Freezer Refrigerator
Water leaking from inside door
I have a Frigidaire top freezer refrigerator with water through the door (GLRT188WDWB) When using the water dispenser, water pours out the bottom of the door. I can even tell how to separate the panels to see whats going on. It seems like I'm going to destroy it to open it up.
  • chopperchesw Jan 21, 2009
    FANTASTIC. Wat is the best way to get a grip on the little bugger to get it started out. Not much material there to pull on.
  • 410 Answers
The water line for the water disp runs in a chase that goes up thru the bottom hinge of the refrig door. SO DONT PULL YOUR DOOR APART! you can order a new water line thru frigidaire and replace the part by removing the water dispenser housing on the door and pulling the line thru the door then inst the new line in reverse. if it looks like too big a job then get a reputable company to inst it for you.
Posted on Jan 21, 2009
  • peyton thompson
    peyton thompson Jan 22, 2009
    once you have everything loose at the disp area you can push some of the line up from the hinge area and get enough line to pull it on out. i wish i had some pics of the process to post for you sorry.. peyton
Water is leaking from the dispenser area as well as the bottom of the freezer door of frigidaire frs20zrg
Hello Dc2464, thank you for your inquiry!
Based off the information you have provided water is leaking from the dispenser as well as the bottom of the freezer door. This is where your water line is located and it is possible that there could be a leak. I would recommend contacting a professional technician for proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jan 14, 2016 | Frigidaire Refrigerators
Refrigerator water dispenser has water to bottom of door but will not dispense
water is frozen up in door. try turning temp to freezer up a little.
ive been able to thaw line by using hair dryer on inside of freezer door
Mar 11, 2013 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
Jul 01, 2010 | Frigidaire FRS3R5EMB Side by Side...
Accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Feb 02, 2009 | Frigidaire FRT21G4B Top Freezer...
Need to clean ice cube dispenser
yes warm soapy water followed by cool clean water.
Mar 28, 2008 | Frigidaire FRT17B3A Top Freezer...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water dispenser
Hello, If you can see the water line inside the freezer case you might try using a hair blow dryer to try to thaw it out to get water flowing again? Good Luck! Dr. Know
Nov 27, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire GLRT188WD Top Freezer Refrigerator Logo
189 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
