Question about Brother MFC-8480DN MFC8480DN Print/Copy/Scan/Fax ENET Duplex Laser Brother
Black line down left side of paper MFC8480DN
I am getting a smudgy broken line down the left side of the paper when printing. I have cleaned everything but it is still persistent. Any suggestions
checkitright
  • 1362 Answers
SOURCE: 2" BLACK LINE
1- itis on the Scanning unit open and look for a thin strip of glass, clean
2-the scanning unit is bad
Assuming it's only on Outgoing Fxs and not incoming as well ( that would indicate the drum)
Posted on Sep 10, 2008
  • 320 Answers
SOURCE: The Black line on the paper when I scan and fax
try cleaning the grid on the drum unit and you might replace the drum
Posted on Jan 20, 2009
SOURCE: black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Posted on Jun 23, 2009
  • 329 Answers
SOURCE: wide black lines down the paper. I have changed
Have you changed the Drum unit. Also there is a cleaning pad that you slide across the corona for cleaning. If you leave it in the middle it will give a black line, should be moved all the way to one side.
Posted on Nov 19, 2009
FixinFax
  • 3085 Answers
SOURCE: A Solid black line down the left side of the page
It could be 2 things...
1. Your scanner glass is dirty...open the doc feeder and clean the glass. probably Wite-Out.
2. A segment of your scanner assembly lamp is burned out. Not good, uneconomical to repair.
Posted on Jan 21, 2010
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Have black lines on left side of paper after printing
Usually this is occurs when the drum needs to be changed.
Jun 05, 2012 | Dell 3100cn Laser Printer
I have black smudgy lines going down the left hand side of my printed copies. What do I do?
1. Check the toner level, when it's low the quality of the prints becomes poor.
2. If toner level is good, clean out the printer inside. The best way is to buy an air compressed can, get the printer in an open space and blow any toner from the inside of the printer. Give it a good clean as there might be residual toner inside that make the poor quality.
Nov 29, 2010 | HP LaserJet P2015n Printer
Lines in printing
...maybe its time to replace fuser fixing film!?
Nov 10, 2009 | HP LaserJet 1020 Printer
A black line is printing on the left side of the
Pull out the toner cartidge, lift the flap and look at the drum, it should be clean. you will have to buy a new cart to fix
Jun 03, 2009 | HP LaserJet 1300 Printer
SMUDGE LINES
I'm gonna assume you have a laser printer. You might need a cleaning since some toner might have spilled when you replace your toner. Toner gets into the rollers inside the printer that pulls the paper thru and creates smudgy black lines.
Check out your local business supply store like Staples for Laser Printer Cleaning paper. It doesn't work 100% of the time depend how dirty the inside of the printer is. Maybe a quick fix then buying a new printer. Getting toner mess out is a a messy job.
Aug 21, 2008 | Sharp AM-400 Digital Multifunction Printer
Smudgy Photo orints
Make sure you are printing on the correct side of the paper. Most photo paper is single-sided. If you print on the wrong side, the ink sits on the surface, pulls up into very small drops, and remains wet for quite a while. If you print on the correct side, the image should be dry to the touch within 15-30 seconds.
Jul 29, 2008 | Canon PIXMA MX300 All-in-One Printer
Blue smudging down left side of the paper and paper turning greyish color
check the fixing unit if the adjustment for envelop is activated or not the same. set to normal.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
Brother MFC-8480DN MFC8480DN Print/Copy/Scan/Fax ENET Duplex Laser Brother Logo
55 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
