Question about Nintendo 64 Console
HELP I HAVE A RFU ADAPTER FOR NINTENDO 64 AND I HOOK IT UP BUT NOTHING HAPPENS. AM I HOOK ING IT UP RIGHT?
  • Anonymous Jan 03, 2009
    same for me...
    Scholar:
  • 59 Answers
Does the console turn on(lights) any sound , I'am going to guess no, if you have a gamecube or snes with rca cables use those and see if it works,the rf adapters for gamecube and n64 are cross compatabile as well, however the one for snes isn't the same, you may just need another cable, also try setting the tv to ch.3/4 and if you have more than one coaxial input try changing to another , if the console is not turning on then it may be a bad power cord or the mem pak isn't seating right or the console has died, most likely the rf switch has died thought, rca will last longer anyway, either go get one from a local gamestore or if you cant find one for 64 get the gamecube cords they have the same connector on the console end. Hope that helps
Posted on Jul 04, 2007
SOURCE:
Nintendo 64 not working
Think I know the problem. It might be the jumper pak. If it is then it would be a cheap fix. This guy gives a good demonstration http://www.youtube.com/watch?v=WqQorcCz4hE
Feb 04, 2013 | Nintendo 64 Console
How do you hook a Nintendo 64 to a tv?
You need the colored cords to hook up into the back of your TV, and you need to keep in mind that a power adapter is needed too to plug into an outlet.
Dec 16, 2011 | Nintendo 64 Console
My rfu cable just has an av and control out cable no rva cables how do i hook it up?
Important Note:
We highly recommend you review the following precautions before you set up and operate your Nintendo system:
Important Safety Warnings & Precautions
Hardware Precautions / Maintenance
Game Pak Precautions / Maintenance
Precautions Concerning TV Screen Damage (Image Retention)
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo A/V cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting the each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo A/V cable into the "multi-out" connector on the back of the Control Deck.
After system is connected to the TV:
Insert Game Pak fully into the Control Deck.
Plug the Controller(s) into the front of the system using the left most port for Player 1.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It's often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You're ready to play!
If after following these directions completely you are not able to view the game, try our Troubleshooting Tips.
Sep 08, 2011 | Nintendo 64 Console
I have an RFU adapter for my nintendo 64. and I don't know what to do or how to connect it!
This link should be of great help to you.
http://www.ehow.com/how_10487_set-nintendo-64.html
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button and leave ashort comment in return. Have a good one!
Jul 22, 2011 | Nintendo 64 Console
I have a nintendo 64 and i cant figure out how to connect the rfu adapter i have to the tv. i dont know which cords go where.
Most if nto all RFU conenct to the coaxle connection on you tv.
If you have a newer tv monitor many do not have coaxle conenctions anymore only RCA/HDMI/C-RCA if this is the case on your tv you'll need to
#1 get rca wires for your 64 (easy cheaper)
#2 get a rf to rca converter (harder more expensive)
Aug 03, 2010 | Intec RFU Adaptor for PlayStation® 2
I have a rfu adapter for a n64
the gamecube video cables will work.
Apr 04, 2009 | Nintendo 64 Console
My nintendo 64 wont come on, ON the tv.
You need a switch (transformer) to connect it to the incoming signal antenna screws. You will probably need to adapt it to a cable tv plug. The wires you connected are for the sound.
Mar 17, 2009 | Nintendo 64 Console
N 64 does nothing
Well its a power supply failure symptom for this to happen now.
Apr 26, 2008 | Nintendo 64 Console
Nintendo 64 Console Logo
1,034 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
