Question about HP Pavilion Computers & Internet
Converting mitsubishi vcr hs-u430
Converting vcr/rca to USB on HP Pavilion computer
  • HP Master
  • 2,385 Answers
converting mitsubishi vcr hs-u430 - images?q=tbn:and9gcqvs1awuoyltxlaa4ky2vkw3di48wh1oeral2aoyra-pmxmqbcr36utsa you can find this type of jack in the market
Posted on Jan 11, 2013
I need an owners manual.
Here is a link to the manual you've requested:
Mitsubishi HS U430 User Manual
best of luck!
Apr 13, 2016 | Mitsubishi HS-U540 VHS VCR
How can i unlock my mitsubishi vcr hs-u430
I am unsure what you mean.
VCRs are not locked to regions like DVD players are, so unless you have locked it to a table or locked it in a closet, I am unsure how to help you here.
We need more information.
Feb 24, 2011 | Mitsubishi HS-U430 VHS VCR
I am looking for a free manual or instruction booklet for a Mitsubishi HS-U430 VCR or a free website to downloand one from please.
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
. Thanks for using FixYa.
Oct 04, 2010 | Mitsubishi HS-U430 VHS VCR
Mitsubishi HS-U540 VHS VCR How do you connect the red, white, and yellow cables?
The RED is Right Speaker the WHITE is Left Speaker and the YELLOW is for
Video. They connect with RCA Cables to the same color coded inputs on yout TV.
You may find it easlier to just use a CoAxial Cable; Use a CoAxial for the CABLE IN to the Cable Box then 1 CoAxial from the Cable Box OUT to the VCR IN then use 1 OUT from VCR to TV IN. That is much easlier then using RCA Cables.
Aug 14, 2010 | Mitsubishi HS-U540 VHS VCR
Can Not Record on The Mitsubishi VCR HS-U430
plz tell us more
tell exactly what you are doing and where does it goes wrong
Apr 07, 2010 | Mitsubishi HS-U430 VHS VCR
Mitsubishi VCR model HS-U430. Cable channels 2-6 fuzzy.
Looks that way,the signal is not getting through the vcr,time for an upgrade
Sep 15, 2009 | Mitsubishi HS-U430 VHS VCR
Is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
May 13, 2009 | Mitsubishi HS-U446 VCR
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
Need a substitute remote for mitsubishi hs-u431
If you go to www.remotes.com you can order an original replacement for your unit!
Please rate my response
Thank
You!
Jan 11, 2009 | Mitsubishi HS-U431 VHS VCR
Initial set up
Hi Hit the menu button, and look for the word "idioma" which means language, and select that. You should then be able to toggle back and forth between English and Spanish. You may have to look under "opciones config. vcr" which is VCR Setup to find it. Hope this helps, Good Luck!
Mar 09, 2007 | Mitsubishi HS-U430 VHS VCR
Computers & Internet Logo
14 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
