Question about Panasonic Panafax UF-890 Plain Paper Laser Fax
When it prints it comes out very faint
Change the toner but it still comes so light you can read the print.
    Sergeant:
  • 284 Answers
Remove the toner . look in on the left hand side where it goes you should see to half loops springs. these might be dirty or bent . this is what gives the toner the charge, if you want to clean them go ahead, if you want to bend them turn the power off first those are high voltage pins.
Posted on Jan 22, 2009
HP LaserJet 3030 Printing comes out light but copies are fine.
Have you calibrated your printer after changing ink cartridges?
Mar 19, 2014 | HP LaserJet 3030 All-in-One
Printing very light Okionly B410d printer usesblack toner cartridge
Try performing a stop test. Send a test page and turn it off mid print. Retrieve the page from the printer to see if the image is readable before it went through the fuser. If so the the fuser may need to be replaced.
Jan 16, 2014 | Oki Electric Industry C3300n Laser Printer
New toners added still feint print
Clean your roller and see if there are loose gears or trapped objects inside. As for the faint prints, check your toner density. The normal setting should be 3
Oct 24, 2012 | Epson AcuLaser C900 Printer
Just changed the toner and the printer now prints faintly
There are two reasons for faint/ light printing:
1- Toner Saving Mode may be turned-on from the printer OR from printer settings in windows
2- There could be dust/ Toner Dust accumulated on the mirrors and lenses inside the printer, which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hope this helps!
CreativeTECH
Dec 20, 2010 | HP P2055DN LaserJet Monochrome Printer
My printer shows ayellow light - toner save-and prints faint
You have change the toner save mode first, in the printing window you have a properties options in that you change the mode of printing, if you turn off the toner saver mode in the properties option you can print the documents in normal, dark printing formats. Thank you.
Oct 30, 2009 | Nikon COOLPRINT Thermal Printer
Printing too lightly
Is the paper hot when you take it off the printer? The reason I am asking is, there is a part called a fuser, its the last process in the printing cycle. The fuser gets to almost 300 degrees to melt the toner onto the paper. If the fuser is not working correctly then the paper will be room temp and their will be no print.
Apr 04, 2009 | Brother MFC 8220 All-In-One Laser Printer
Faint repeating
I have problem with my Phaser 6130 Laser Printer, I changed toners (black, cyan, magenta yellow). My printer printing only cyan and magenta, colors black and red is very, very light. I cleaned my printer exactly. Everything is ok, but he does not has a black & magenta toners. What's happen? I don't know.
Donna
Jan 30, 2009 | Office Equipment & Supplies
Printing is faded and too light
more important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Oct 23, 2008 | Dell 1600n All-In-One Laser Printer
Faint printing quality
the problem isn't with the toner. you have to check the fuser unit
Oct 16, 2008 | Samsung ML 1510 Laser Printer
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
Panasonic Panafax UF-890 Plain Paper Laser Fax Logo
49 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
