Question about Asko D1706 Built-in Dishwasher
Asko D1706 - filter is stuck we can't remove it...any suggestion???
Try a few drops of liquid wrench on it, wait half an hour and try turning counter clockwise again.
Posted on Aug 29, 2013
3 Suggested Answers
SOURCE: Asko D1706
I live in Australia, My one had the same problem, I found them in e-Bay.
Posted on Dec 25, 2008
  • 14 Answers
SOURCE: Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Posted on Jun 18, 2009
Drain pump small black insert, found in the sump area. Where can I find one of these for my ASKO D1706 Dishwasher?
call asko directly, or call Great Plains Appliance Parts. Don't know the numbers, but Asko stocks parts in Texas, and Great Plains stocks them in Denver.
Aug 29, 2013 | Asko D1706 Built-in Dishwasher
I have a dishwasher AEG BM335 super cleaning system. I got a message: F2, and machine stoppet washing, all red lights are on. What can I do? Is any hope for repairing? My name: Arna...
Hi
F2 error in your Asko dishwasher indicates that the water is not draining or is unable to drain and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Asko D1706 Built-in Dishwasher
Asko D1706.The washing arms have stopped turning.
Can you hear the motor running? If the motor is runningand machine is full of water, but not pumping water around, you have one of the following problems:
-a blockage in the filters or sump preventing enough water getting to motor impellor,
-blocked jets in spray arms themselves,
-or I have had cases where the impellor has broken off the motor, hence motor runs but doesn't pump any water around. Check for blockages first, wouldn't suggest you take motor out and disassemble unless qualified or confident to do so (it's not an easy job if you haven' done it before!!)
Aug 04, 2009 | Dishwashers
Asko door latch stuck
The only way is to pull out the dishwasher ,unhook the latch and then unscrew the door panel.your dishwasher is installed with 2 screws to the underside of your countertop. its tricky but youll have to remove them adjust to leveling legs down this will give you more room to get some head bit in ther to remove the screws if its out then slide the d/w foward ,remove the strike plate door will open then you can get your dishes out first
Sep 20, 2008 | Asko D1706 Built-in Dishwasher
Asko D1706
Sep 10, 2008 | Asko D1706 Built-in Dishwasher
Asko D1706
Jul 06, 2008 | Asko D1706 Built-in Dishwasher
Asko D1706 No water in the sprinklers
You can get access to the base from behind the dishwasher ,you will find about 6 screws to remove the back panel at the bottom to see if its leaking.
Feb 17, 2008 | Asko D1706 Built-in Dishwasher
How to clean filters
The fine fitler screws out by twisting the entire unit counter-clockwise. The threads are built into the filter unit itself. There are no screws to remove. Hope this helps.
Dec 03, 2007 | Asko D1706 Built-in Dishwasher
Asko D1706 Built-in Dishwasher Logo
137 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
