Question about Canon PowerShot S5 IS Digital Camera
Card lock for powershot S5IS - Canon PowerShot S5 IS Digital Camera
  • ARCHANA Jan 15, 2013
    i am from bangalore , my canon camera had a lens promblem and i got a good service from mata cameras at sp rd , near town hall.they repaired my camera in 2 hours and i appreciate their service, canon users can contact mata cameras at sp rd 9035871324. its on 1st floor. thanx
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on Jan 11, 2013
drumbanger
  • 1199 Answers
SOURCE: Cannot unlock memory card for my Canon Powershot S5IS
OK take out the memory card and on the side of the card is a small switch...slide the switch to the unlock posistion and that should fix ya
!Please rate this response and help us keep this area free!
Thank You!
Posted on Jan 21, 2009
zohail
  • 1223 Answers
SOURCE: Reformatting SanDisk for Canon s5is
y dont u format it on windows try card reader if nothing happens then ur card is faulty it seems like
Posted on Feb 23, 2009
robmcd27
  • 423 Answers
SOURCE: Camera won't read memory card!
Hi there and welcome to FixYa. There could be a couple of things off the top of my head that could be giving you the problem, so we'll try solutions for them both.
A) Go into the menu of your camera and format your cards. Your camera won't save pictures to a card properly if you don't format it first. - Go into the Setup menu for this. And remember, you have to format the cards in the camera, don't use your pc or a card reader.
B) The above will take care of your problem unless.... your cards are locked. SD cards have a switch on the side of them so you can lock the card (it prevents accidental erasure). In that case, unlock it with the switch on the side. Let me know with a comment if you have any questions or problems, or if either of these solutions doesn't do the trick.
Rob
Posted on Mar 01, 2009
  • 11967 Answers
SOURCE: canon powershot s5is isn't connecting to computer
Use a card reader.
Posted on Mar 18, 2010
  • 11967 Answers
SOURCE: i have a canon PowerShot S5IS that doesn't turn on
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 01, 2010
Cannon s5is powershot as soon as i turn camera on a memory card error comes up and theres no card in it, does same thing when card inserted. it's got to be something in the camera slot, is there a lock in...
On the SD card there is a little switch you can move. It has 2 positions, LOCKED, and UNLOCKED. To make the card available, put the switch in the UNLOCKED position.
Here is an example-
If that doesn't work, try putting the card into a memory card reader, like on your PC or a special USB attachment. If the memory card is recognized, then it might be a problem with your camera.
Mar 01, 2011 | Canon PowerShot S5 IS Digital Camera
Canon Powershot S5iS message: Card is locked@
On the card itself is a smal switch on the side. It must be in the locked position and that is why you can't do anything with it
Feb 01, 2011 | SanDisk 2GB microSD Memory Card
Is the SDHC memory card compatible with the Canon Powershot S5is Camera?
Yes, the S5 IS is compatible with SDHC cards. You can use them freely.
Nov 27, 2010 | Canon PowerShot S5 IS Digital Camera
Canon powershot s5is isn't connecting to computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 10, 2010 | Canon PowerShot S5 IS Digital Camera
Can you change or add a diffrent lens to a cannon powershot S5IS
Yes you can. But you have to visit a canon service center and order them to your lense.
Jan 29, 2010 | Canon PowerShot S2 IS Digital Camera
Is there a program to download movies and pictures from my Cannon PowerShot S5IS digital camera?
Yes but you could use a card reader to download your pics and movies to a folder you create on your desktop. From there, you can use programs already on your computer to open them.
Dec 07, 2009 | Canon PowerShot S51S Digital Camera
Rob
Mar 01, 2009 | Canon Cameras
Feb 23, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
Thank You!
Jan 21, 2009 | Canon PowerShot S5 IS Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
