Question about HP Photosmart 375 InkJet Printer
HP Photosmart 375 printer says ink cart door open it is closed
When you turn the printer on it says the ink cartidge door is open and it is closed . I have opened and closed several times even put new cartidge. I push okay and still does the same. help
SOURCE: HP Photosmart all in one C3180
My suggestion: Don't buy HP. I have the same region coding problem. All I want to do is buy HP ink, put it in my HP printer and print stuff. Too hard. I've wasted 30 pounds on ink and another 30 pounds on "support" phone calls to HP. Hopeless. I will never buy HP again. Waste of time and money.
Posted on Nov 19, 2007
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Posted on Apr 06, 2009
  • 4 Answers
SOURCE: Door open error on HP6840 printer when door is closed
Here's the answer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065334&cc=us&lc=en&dlc=en&product=385458
The sensor is probably stuck, and it took me a few minutes to fix!!
Good luck...
Peter
Posted on Apr 30, 2009
Chittaranjan
  • 62 Answers
SOURCE: Error message coming up: The HP LaserJet 1020 has
send your printer for service. seems like, one or two sensors are malfunctioning.
Posted on Aug 09, 2009
SOURCE: My HP Photosmart 3210xi cartridge door is also locked in open
There's no sensor, it's just a spring and a plastic wedge thing.
Using a #10 torx driver, remove two screws holding the right-hand side panel from the printer. (one in the back, one on top underneath the ink access door.) Unsnap it and set it aside.
Disconnect 3 small ribbon cables and one 5-pin connector that lead from the printer to the access door/scanner.
Remove the lid from the flatbed, then remove the access door from it's hinges. Use the torx driver and unscrew the hinges from the main scanner body.
Lift the hinge assembly from the scanner and push the steel pin out, seperating the two parts of the hinge.
From there you should be able to loosen them up, remove the springs, lubricate them, or find whatever the problem is.
Reassemble and you're done.
Posted on Feb 21, 2010
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
HOW DO I INSTALL THE INK CARTRIDGE IN PHOTOSMART C4280
Turn on power to printer, then lift the top half of Printer lid, the cart holder will move to centre, place printer cart in the holder rack, press firmly in place.
Jun 07, 2010 | HP PhotoSmart C4280 Laser Printer
Not sensing the ink cartridge
In this scenario you should check with a new set of black cart or you can try by cleaning the cart with a lint free cloth. and try with resetting the printer as well. if it doesnt work then printer might have gone bad
Oct 21, 2009 | HP Photosmart C6280 Printer
Ink cartridge not recognized
First, I would try to remove both of the cartridges, close printer, power down, and remove power cord and let sit for 5 minutes. Reconnect, reinstall the carts, and see if problem still occurs. Otherwise, I would also go to this link and select "check to see if I have the latest drivers" at the top of the page and update your software. Also, if you have another color cart, switching it with a new one would also be an easy step to see if it is just a cart issue.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=441240&lang=en#
Mar 12, 2009 | HP Photosmart 2575 All-In-One InkJet...
Printer Align keeps failing
Replace both ink carts at the same time with GENUINE HP ink carts.
Jan 29, 2009 | HP Photosmart C4150 All-In-One InkJet...
Printer Designjet 110 Plus not working
Ink supplies Description HP part number 11 Black Printhead C4810A 11 Cyan Printhead C4811A 11 Magenta Printhead C4812A 11 Yellow Printhead C4813A 10 Black Ink Cartridge C4844A 82 Cyan Ink Cartridge C4911A 82 Magenta Ink Cartridge C4912A 82 Yellow Ink Cartridge C4913A
alot of printers now if the ink in the cartidge is the first ones placed in the system from the box are those that are only half full if not less depending on the maker but I know HP only fills their cartidges only just under the half way make but the printer sees it as a new cartrige because of the chips programming.
Have you tryed to turn the power of and let is sit for about 5 mins and turn it back on with the same result? (ushally a yellow error light is on)
Also if you can find the settings to only print in black and white on the printers properties that might also work as well for a temp fix.
But ushally once one ink runs out it likes to do that you where correct with the "is it because of the finished color cartidges.." either that or the carts all have finally expired.
Nice printer by the way.
But your best way to do it would be to replace the color carts and if not reasonable to do now there is also a way to reset the color carts so that the printer thinks that there is ink in them as well.
hope this helps you a bit if you need more info please let us know.
Aug 02, 2008 | HP Designjet 110plus nr InkJet Printer
Printer Door
I have that exact problem at work. There is a bump on the right side of the lid...and when you close the lid it presses on a lever. Check and see that the bump actually pushes that lever downwards. That's how the printer determines that it's closed.
Feb 03, 2008 | HP DeskJet 3650 InkJet Printer
How to put ink in ahp photosmart 1215 printer
Hiya
Just above the paper slot there is a flap that opens, The cartidges go in there,
Hope this helps
Oct 18, 2007 | HP PhotoSmart 1215 InkJet Printer
HP Photosmart 375 InkJet Printer Logo
99 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
