Question about Home Security
How do I open my uscan d-2736slc safe with the factory code
2 Suggested Answers
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Posted on Dec 18, 2009
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    How can i drill a hole into my keepsafe wall safe to open it?
    Keep the drill motor in the toolbox, you'll likely just ruin the safe.
    Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
    There are 3 possible ways to unlock and access
    the safe:
    1. Factory code
    (Found on the first page of the factory guide) You can
    always open the safe by entering the pre-set 5-digit
    factory code. This code cannot be deleted.
    2. User code
    If you prefer to employ your own code, you can
    program the safe to open using a 5-digit user code
    of your choice.
    3. User pin
    If you wish to give someone else temporary access
    to the safe, you can program a 5-digit user pin that
    can later be erased.
    Programming the user code
    NOTE: One (1) user code is allowed.
    To add:
    1. Press the Prog key , then enter the 5-digit
    factory code.
    2. Enter the 5-digit user code of your choice.
    To delete:
    1. Press the Prog key.
    2. Enter the 5-digit factory code twice.
    Programming user pin
    NOTE: One (1) user pin is allowed.
    To add:
    1. Press the Prog key 2 times.
    2. Enter your 5-digit user code.
    3. Enter the 5-digit user pin of your choice.
    To delete:
    3. Enter 0, 0, 0, 0, 0.
    NOTE: If your safe does not appear to be working,
    please check batteries before calling Sentry
    Customer Care.
    Jul 26, 2014 | Sentry KeepSafe Combination Fire Safe 12...
    Lost factory code for sentry safe model #d8W5840
    did you ever find the factory code? I lost mine also. if you have the factory code for this model please message me on facebook.com/vernhartjr
    Sep 09, 2012 | Sentry Safe Sentry Fire-Safe Combination...
    Cannot open safe and I have changed the battery
    If you removed batteries more than 1 or 2 times in a row, safe may revert back to a factory setting.
    The factory number should be on your instruction sheet that came with the safe.
    Contact Sentry for the factory safe number that came with your safe.
    However, if the safe was not opening before you replaced the batteries it may be a faulty solenoid.
    Terry Whin-Yates BA Hons (Criminology)
    3rd Generation Master Locksmith
    25+ Years Experience
    BC Security License : B4227
    604-773-5625
    http://www.mrlocksmith.com/
    Dec 27, 2010 | Sentry Safe Qe4531 Firesafe Waterresistant...
    Opened micromark safe using factory code, how do i change this to a personel number ?
    Hi have micromark electronic safe no EX2003085561 when i enter code top right hand green light flashes and lock will not open any assistance gratefully accepted
    Stewart
    Nov 23, 2009 | Safe International Digital Electronic Safe...
    Sentry Safe (DSW3607 Model) Won't Open
    I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
    Mar 22, 2009 | Sentry Fireproof Safe
    New Lexsor safe LXo24 Model
    Hi there, I had the same problem yesterday but luckily remembered the code and got the safe open. The factory pin is 159B.
    Regards Norma
    May 27, 2008 | Ventamatic Gable Mount Power Attic...
    Home Security Logo
    258 people viewed this question
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
