Question about Sony CPD G520 (Blue Grey, Gray) 21" CRT Monitor
No Picture After turning my monitor ON, I can see the green light lit but now picture showing on screen, not even OSD. I tried both Video1 and Video2 but failed. What possibally could be the problem(s)? Max
  • Max 665
    Max 665 Jul 07, 2007
    Make sense... What should be my action items after opening the monitor?
  • 65 Answers
You have brightness and/or flyback problem...
Posted on Jul 07, 2007
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
Pip now is on the souce menu whereas cable, video1, and video2 were there before. How do i get rid of pip and return to the former sources?
close the pip window first
if your tv/video button on your remote brings up
an input selection menu either press the number
of the ones you want or use the chan^chanv buttons
to select
Nov 29, 2007 | Zenith A27B33W 27" TV
My computer monitor is a black screen....the light is lit solid green and I can hear the software playing just no picture
If the light is green, I suspect that the backlight has gone out on you. This could also be caused by you having the brightness turned all the way down.
Oct 04, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
Lg2234s monitor goes of blinking...cant turn monitor off (blue light remains off) then monitor turns on ..screen pic returns but is totally green, the OSD becomes garbled, if set to return to default then...
emale36, Could be problem with the "switch-mode-power-supply" inside the unit. If dc voltage rail is noisey or marginally on the low side of rated specification then strange things will start to occur on screen. Contact LG (Lucky-Goldstar) if unit is covered by warranty. The unit will need to be evaluated by technician. Visit YOUTUBE to see video clips of monitore being repaired by their owners. Read more of my profile responses to other LCD owners. 12fixlouie
Dec 06, 2009 | Computers & Internet
Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
Apr 05, 2009 | Acer AL1713M 17" LCD Monitor
Lcd 17"monitor phillips 170b4bb
that video input board will have to be replaced.
been there , done that.
Apr 25, 2008 | Computers & Internet
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Can't get componet Video to work
Make sure you have an input Video signal on that Yamaha Reciever (exa. DVD, Cable box, etc...) then choose the right input selection on ur receiver (Video1, Video2, AUX, etc..), then connect ur TV on the receiver Monitor Video out. And put your TV on the right VIDEO input too (Video1, Video2, AUX, etc..). Goodluck
Aug 10, 2007 | Yamaha HTR-5930 Receiver
Open Questions:
See all Sony CPD G520 (Blue Grey, Gray) 21" CRT Monitor Questions
Sony CPD G520 (Blue Grey, Gray) 21" CRT Monitor Logo
83 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
