Question about Brother HL-2280DW MFC / All-In-One Up to 27 ppm Monochrome Wireless Laser Printer
How to turn on a brother printer - Brother HL-2280DW MFC / All-In-One Up to 27 ppm Monochrome Wireless Laser Printer
MFC-665CW won't turn off?
Brother MFC-665CW Quick Start Manual - ManualsLib
www.manualslib.com > ... > All in One Printer > MFC-665CW
View and Download Brother MFC-665CW quick start manual online. Brother MFC-665CW: Quick Start. MFC-665CW All in One Printer pdf manual download
Aug 30, 2015 | Brother MFC-665CW All-In-One InkJet...
Loss of power when printing
  1. Is the printer off?
    Press the I on the power switch to turn the printer on.
  2. Is the power cord loose or disconnected?Turn the printer off and connect the power cord properly. Turn the printer on again.
  3. Is the printer connected to a correctly rated outlet/socket?Connect the printer to an AC power outlet/socket that you know works. Do not connect any other equipment to the outlet/socket. Do not connect the printer to an auxiliary power outlet on the back of a computer.
  4. Is the printer defective?Turn the printer off immediately, disconnect the power cord from the outlet/socket, and contact your dealer or Brother Customer Service.
    Still having Problem Then follow Us For
Brother Printer Support
Mar 23, 2014 | Brother MFC Office Equipment & Supplies
MFC465CN-PAPER JAM- NONE IN MACH.CANT USE
Sir/Madam
MAKE SURE YOUR BROTHER MACHINE IS THE DEFAULT PRINTER
If the printer driver is not set as "default printer", you can not print. Make sure your Brother machine is set as default printer. If your brother machine is not set as default printer, set it as default printer.
  1. Click Apple Menu and choose System preferences..., click Print & Fax, Print & Scan or Printers & Scanners.
  2. Choose from pull down menu of "default printer".
DELETE ALL PRINTER JOBS
  1. Click Apple Menu and choose System preferences....
2 Click Print & Fax, Print & Scan or Printers & Scanners.
For Mac OS X 10.5 - 10.7 users
Choose the print job (1) and click Delete (2).
CHECK THE PRINTER STATUS
Choose brother machine's icon and click "Open Print Queue..." then check the printer status.
The Resume or Resume printer icon which is surrounded by red lines is displayed in printing when the printer is out of paper or the printer is turned off and on. Click Resume or Resume printer.
For Mac OS X 10.8 or later users
If you connect the brother printer via USB cable, the error message The printer is not connected or Offline is displayed on Print Queue when the USB cable is disconnected or the brother printer is turned off. Connect the USB cable and turn the brother machine on.
If the other error message is displayed on Print Queue, check if the LCD display or LED indication of your Brother machine is not showing some error. If an error is displayed, go to the Troubleshooting section and find a solution.
REGISTER THE PRINTER ICON AGAIN
  1. Choose your printer icon.
  2. Click [-] button to delete the printer icon.
  1. Click [+] button to register the printer icon again.
In spite of if you click [+] button, the brother machine is not displayed, then the brother machine is not recognized.
If you use the printer via USB connection, reconnect the USB cable or restart the Macintosh or your brother machine.
For Mac OS X 10.4 users
I Suggest You Go To Official Brother Printer Website For Brother Printer Troubleshoot:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000046/faq002646_001.html?reg=us&c=us&lang=en&prod=mfc5860cn_all
Or
If You still having Problem Then Follow Us For Brother Printer Support
Jan 23, 2014 | Brother MFC 420CN All-In-One InkJet...
Will no longer print via wireless network and indicates that it cannot find the printer
I just had this issue yesterday.
Step 1. Turn off your Brother
Step 2. Turn off your Wireless DSL/Router
Step 3. Turn on the Wireless DSL/Router
Step 4. Turn on your Brother Printer
Apr 06, 2010 | Brother MFC 7840W Printer
Brother printer won't recognize ink cartridge.
I use generic cartridges all the time in my brother printers with no problem. better to pay $2 per cartridge than whatever the brother brand ones cost!
Jan 03, 2010 | Brother Multi-Function Center MFC-240C...
Brother hl-5270dn is desplaying the error code S01? What does this mean?
S01 = Fatal error EX
1) turn off the printer
2) wait a few seconds
3) turn it on again
H63 = DRAM access error
3) turn it on again
Sep 11, 2009 | Brother HL 5250DN Laser Printer
When power is turned on all lights come on solid. Printer will no
brother's site says to hold the blue 'go' button down for a few seconds and it -should- cycle through this; others have stated to hold the button down before powering up the unit.
Also see Brother's site re: document too large to print/ over-run buffer issues.
or , others just unplug it for anywhere from 15 minutes to a couple of days..
Nov 15, 2008 | Brother HL-2040 Laser Printer
My Brother HL 1440 laser printer works but keeps turning off
I frequently have the some problem. I find that if I power on the printer and then turn it bock on, the printer will print what is in the print que.
Oct 26, 2008 | Brother HL 1440 Laser Printer
Brother printer.
the main circuit baord is defective. Sorry, you cant fix it anymore!
Jan 20, 2008 | Brother MFC-620CN All-In-One InkJet...
Brother HL-2280DW MFC / All-In-One Up to 27 ppm Monochrome Wireless Laser Printer Logo
209 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
