Question about Pioneer Audio Players & Recorders
I have a AVH-X2500BT I am trying to play a dvd. an error code 02-9e comes up. what is the problem?
Error code of 02-9E comes up
  • Pioneer Master
  • 5,159 Answers
The error indicates that the AVH-X2500BT can't read the disc. The DVD could be dirty or scratched or upside down in the tray. Try cleaning the disc or putting in another DVD. The other issue is a mechanical or electrical problem with the unit. Turn off the car's ignition then press the Reset button on the unit. The reset button is recessed and has to be pressed with a pen tip (it's on the far left of the front button array).
The manuals for the unit is available here: http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVH-X2500BT_OwnersManual010213.pdf . See page 4 (page 7 of the PDF) for the location of the Reset button. You will need Adobe Reader or a similar program to read the manual. If the reset doesn't work, you ,may need to have the unit serviced. (Check that your electrical system doesn't have any fuse or ground problems first.)
I hope this helps.
Posted on Jan 11, 2013
  • 2 more comments
  • Andrew Jan 11, 2013
    Thank's, The unit is new and installed myself with the needed connectors supplied by the company.All the wiring is matched up. the only wire I have not hooked up is the gree wire to the parking brake Any thoughts?
  • Cindy Wells Jan 11, 2013
    I believe you need to connect the light green wire for the parking brake to use the DVD. There is an interlock that prevents the unit from playing a DVD while you are driving. (This avoids driver distraction.) Unfortunately, it interferes with normal use if the DVD monitor is set up to be viewed only by back seat passengers. Cindy Wells
    Thank's, I will be connecting the wire over this weekend. Then I will retry playing a DVD.
    You're welcome. I hope the unit works when the parking brake is on after you finish the wiring. Cindy Wells
AVH P3100. What does error code 02-9e indicate?
Error 02-9E Means there is a scratched or otherwise unreadable disc. The problem could be the laser as well. This error can mean any of the following:
Scratched disc
Improper media Bad burn/copy of disc
Improperly adjusted laser - requires an alignment
Dirty Laser Lens (smokers will experience this more often)
Laser failure etc.
Try changing the CD/DVD you are using and if you are still getting the same error, then try to visit you nearest Pioneer Service center and get your headunit's laser tested for allignment. How much you'd invest for repair must be below the cost of a new one or it's not worth it.
Nov 30, 2015 | Televison & Video
Why is it error-10 on my pioneer?
The manual is clear about this. There is a power failure to the bluetooth. If switching off and on (ignition switch) does not help, you should contact a dealer or a repair centre.
May 14, 2014 | Pioneer AVH-X2500BT
Dvd region change AVH-X2500BT
Hey,
I own the exact same model as you and I found a video on youtube explaning how to bypass the DVD region. I bought it in the States (region 1) but I live in Brazil (region 4).
See this and if you are not going to intall it yourself show it to yout tech guy: http://www.youtube.com/watch?v=lDGZEZrUdRo
Hope this helps!
Apr 08, 2013 | Car Audio & Video
Pioneer avh-p6500dvd error 02 9e
there is a small little rubber band that drives the gears that opens the tray. It is possible that this has either broken or come off track. You may need to pull the unit out and remove the cover to see, or if your not comfortable doing this take it to like a best buy or something and their techs can help you out.
May 17, 2010 | Pioneer AVH-P6500 Car Video Player
I need I region free for avh-p4100dvd
Sorry Luis you need to buy dvd made for American market to be played in your system.
Dec 13, 2009 | Pioneer AVH-P4100DVD Car DVD Player
Avh-p5900dvd... I keep getting error -02-9e and it wont play cd,s or dvd,s can you help.
Owner's manual doesn't really say what the -02-9e error code means other than a disc error. They do recommend resetting the unit as a possible solution:
  1. Turn the ignition off.
  2. Remove the faceplate.
  3. On the right side of the front of the head unit (with the faceplate removed), press the reset button with a ball point pen.
You may have to call Pioneer directly to find out what the -02-9e code means specifically. 1-800-421-1404
Apr 03, 2008 | Car Audio & Video
Avh-p5900dvd when trying to play dvd or cd comes up with...error-02-9e can you please help.
Here is the Pioneer error code table:
First Second Error
Digit Digit Description
0 No major error
1 Antenna not connected
2 Shorted antenna cable
3 RF circuit failure - PLL not synchronized
4 Undefined/Reserved
5 NVM Error
6 Defective CAP or not connected
7 Unknown DSP SW version
0 No minor error
1 CDEC Communication Error
2 SSDEC Communication Error
3 SSDEC No Response (DSP core freeze)
4 No signal/100% BER
5 Not activated
6 Not authorized
Your error indicates an
SSDEC Communication Error.
You should try resetting the unit to clear this error.
Apr 02, 2008 | Televison & Video
Error message
try removing power from the unit for about 5 minutes and plug the harness back in. If that doesn't work, it will need to be repaired.
Apr 09, 2007 | Pioneer AVH-P6500DVD Car DVD Player
660 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
