Question about Samsung LN-S4051D 40 in. LCD Television
What capacitors for samsung le40a656a1fxxh - Samsung LN-S4051D 40 in. LCD Television
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
Jan 05, 2016 | Samsung Televison & Video
No picture on tv samsung
Capacitors are blown. I have repaired a few of these. Samsung is known for putting capacitors in that are just big enough to run the TV. They last about 1 to 2 yrs and then blow. Check out youtube and see what there is on there. I replaced all the capacitors on mine. There were 11 of them. I put in a slightly larger capacitor size. It works well and has been for 2 yrs now.
Apr 11, 2015 | Samsung Televison & Video
NEED VALUES FOR CAPACITORS LE40A656A1FXXH
those values are printed on the side of the capacitors. You can tell which ones need replaced by their bulging tops.
Mar 03, 2014 | Samsung LN-S4051D 40 in. LCD Television
Samsung blown capacitors
Hello Chuck,
Before you replace the capacitors on the power supply board you need to check with Samsung. Your TV model falls under the class action lawsuit settlement and Samsung has agree to repair any TVs with faulty capacitors on the power supply board that were affected. You can get full details on the settlement here:
http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
This settlement covers any listed unit for 18months starting Mar 2 2012.
BuddyMc
Jul 27, 2012 | Samsung LNT4665FX 48 in. LCD TV
When i turn my samsung tv on no picture comes up or any sound other than a clicking sound from the back of it somewhere near the top left of the tv,. could this be the capacitors?
No
The clicking is the power relays coming on.
Do you get a flashing power light on front ?
you will need to have it serviced.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung 32'' LN32A330J1 not turning on
Check this website to find the part(s) you need.
Dec 29, 2009 | Televison & Video
Samsung 46" pink dots
I had a problem with the TV going on and off several times before "warming up" and then having pink dots. I would have to reboot to get rid of the dots. I called 1-800-SAMSUNG and reported that I had problems with the capacitors. That is what was causing the problems - cheap capacitors and Samsung is aware that this has caused many TV's to malfunction. My set was not under warranty but Samsung sent a technician across two state lines to fix my TV. As long as the problem is the capacitors Samsung will cover this service call 100%. My TV is fine now. BTW - capacitors which are sold in Radio Shack are not expensive. Why Samsung chose to put the cheapest Korean capacitors in their expensive TVs is a mystery.
So if your TV need warming up and has pink dots on the screen - call 1-800 -SAMSUNG and tell them your capacitors are malfunctioning.
Nov 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN26A450 LN26A450C1DXZA won't turn on
I had the same problem with my Samsung LN26A450 LCD TV. I found the following YouTube video http://www.youtube.com/watch?v=Mm51C_RDIZE titled "Samsung TV Repair - Part 1 of 2) (also watch Part 2 of 2) which shows how to easily fix the problem. The problem is bad capacitors on the power supply board. My TV had seven (7) bad capacitors - all 7 had dark stains on the ends from leaking electrolytic fluid and one (10V 2200MFD) was blown with bulging ends. I ordered 7 new high-temp (105 degrees C) aluminum radial capacitors from DigiKey.com matching the Temperature, Capacitances and Voltage Ratings for each damaged capacitor that I removed. I followed the instructions in the video except I used desoldering braid ($3.99 at RadioShack) to remove the solder attaching the bad capacitor leads to the power supply board. Once you wick up the old solder from all sides of each lead wire using the desoldering braid, the bad capacitors are easily removed. Total cost of repair including soldering equipment was less than $50. Thanks to “The Professor” for posting the video and saving me $400.
Sep 24, 2009 | Samsung LN26A450C LCD TV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Samsung LN-S4051D 40 in. LCD Television Logo
96 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
