Question about Lexmark E234 Laser Printer
Lexmark E234 Paper jam light wont go off
The paper jam light came on. I checked all of the compartments and no papper is jammed. The error code says jam in tray 1... but there is nothing
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 21, 2009
Printer says papper jam but thier is not any paper jam
Be sure that there is a paper jammed inside. You cant just see it.
May 09, 2014 | Lexmark S515 Multifunction Printer
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
When i have no papper in the printer it keeps saying that it is jammed but i checked evrything and there is no papper
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jan 04, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My printer pulls the papper half way to print and then it sound if it was printing but the papper doesn't move i already restarted it unistall the program n reinstall and it still does the same thing
check paper path with test print
right click printer icon go to properties click test print
can you see and remove the jam in paper path Check rollers for slick coating on them they are soft rubber and can get glazed so to speak
remove all parts that you can including paper drawer recheck the paper slot adjustments
sounds simple fix just recheck the paper path for jam or glazed rollers
1 Question ??no error message ?
Jun 11, 2010 | Lexmark Office Equipment & Supplies
On my Lexmark E234 the fourth light down, yellow light is on.
Hi, That light is indicating that there is a paper jam in the printer. Here is a link on how to remove the paper jam and some other instructions on how to prevent it.
Dec 10, 2009 | Lexmark E234 Laser Printer
Paper stops
Check that the rear paper sensor feeler arm is not broken. It is the little black plastic tab that sticks up in the middle of the paper path when your looking at the back of the printer with the cover open. If you can't see it, it's probably broken.
Aug 06, 2008 | Lexmark E234 Laser Printer
Papper jam.
There should be a door on the back of your printer, scanner, copier. Open that door and see if you have a paper jame there.
Apr 20, 2008 | Office Equipment & Supplies
Paper jams
Fan your paper.
Meaning take the paper in your hand and wave it around or page thru the papers, This puts air between the paper to prevent jams.
Make sure you do not over due the paper in the tray. Try lighter paper weight.
Nov 13, 2007 | Lexmark E234 Laser Printer
Lexmark E234 Laser Printer Logo
358 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
