Question about Garden
Spark plug for victa v40
What spark plug do i need?
2 Suggested Answers
shahidkap97
  • 392 Answers
SOURCE: wheres the air filter on a victa v40
see this vide,it says where the air filter is
Posted on Apr 07, 2012
What size spark plug does a Victa 4215 HXT use
Contact Victa customer support at his link. After they give you the spark plug number, go to Bunnings and buy one.
http://www.victa.com/au/contact-us/
Apr 04, 2015 | Garden
Victa.two.stroke.wont.start
www.victa.com/au/support-centre/owner-guides
check spark.
If ok. chec for fuel inside on plug. If ok
check compression of engine.
Oct 12, 2014 | Garden
V40 4 STROKE VICTA STARS AND STOPS
Change the spark plug or could be wire fault
Jan 05, 2014 | Garden
Lawnmower manual FOR A VICTA TWO STROKE
With a Victa lawnmower you must be an Aussie!! Try Retrevo Manuals.com A bita dicken around but shift hot for all sorts of directions
Jan 04, 2014 | Sewing Machines
My accelerator cable on my Victa V40 appears to be looser now so when I pull the cord off choke the revs no longer increase, how do I fix it?
hi.. the thottle cable has round end has poped out of its cam housing(gray plastic) inside the plastic carby... the only way to fix that is to remove the carby, but before you do clean your mower as you will create more issues if dirt/grass gets into the parts you will be working on...also take pictures before you start taking thing off, so you know how to reassemble it, as the carby will need to be taken apart....good luck
Jan 01, 2014 | Briggs & Stratton Garden
How do I adjust the throttle on my V40 Victa lawnmower?
There should be spring where you can adjust near the motor
Jan 01, 2014 | Garden
Wheres the air filter on a victa v40
Apr 07, 2012 | Garden
My 4 stroke victa will not start. I have removed the spark plug and checked for a spark, there is no spark. What should I be looking at now?
Check on any safety interlocks.
Is there oil in the engine? Some engines have low oil interlocks.
Are there any other safeties?
Is there a key or on/off button?
Stick a phillips screwdriver in the spark plug connector, hold the screwdriver close to the engine, spin the engine, is there spark at the gap?
If so, try a new plug.
Dec 22, 2010 | Garden
I am changing spark plug in my 2000 volvo v40
Firing order is 1-3-4-2 (Please rate me if this helps)
Jun 04, 2009 | 2002 Volvo V40 Wagon
Victa 2 stroke mower will not start
It may have a blown crankcase seal. How did you check the plug for spark?
you can remove the carbi and spray 2 stroke fuel directly into the chamber and try to start it.
If it starts you have a problem with the carbi or the fuel supply.
Take out the air filter as it may be blocked and restricting the air supply.
The float in the carbi may be full of fuel due to a hole in it or the fine fuel filter in the carbi may be blocked
Apr 04, 2009 | Garden
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
