Question about Aqua Flo Aquaflo Flo - Master Xp2 2 Speed 2 1/2 Hp 230v Pump Pmp Aqf 061253952040
Aquaflow 07140001-6 hums but can be manually starter
Pump will not start during the filtration cycle a humming sound and three flashing light on panel how ever I am able to start pump when I push pump button on control panel I may be wrong but info is that the starter cap is faulty can this be replaced when started pump functions normally with good preasure
  • 717 Answers
This usually means you have a bad motor. It has found a flat spot on the windings.
You will need a new pump for the fix.
Rod
US Parts Center
Posted on Feb 06, 2013
5 Suggested Answers
  • 3 Answers
SOURCE: hot tub pump will not
This can be one of three issues.
1.  Starting capacitor as you have suggested.  You can take the capacitor to a motor shop and have it tested or test it yourself if you have a meter that will check capacitance. 2.  Low/High voltage.  If the voltage is not at the proper levels (10% up or down) then the unit may have a hard time starting. 3.  Something might be binding up the impeller.  Disconnect the power and carefully check to see if the shaft of the motor spins freely. 4.  A short in the windings.  If none of these seem to be the problem, then you will probably need to replace the motor.
Posted on Jan 12, 2009
  • 77 Answers
SOURCE: I have a 2HP 230V AquaFlow pump model 06620390-2.
Check or substitute motor capacitor
Posted on Aug 18, 2009
  • 990 Answers
SOURCE: Aquaflow pump isn't pumping fully
A common problem here is a clogged impeller. If you open the lid on the pump and reach into the impeller through the hole behind the basket with a small screwdriver or needlenose plier. You may feel soft or spongy materieal inside the unit. Work this in a counter clockwise motion till it loostens then grab with the needlenose and pull out. Repete as nessary, usually one or two times will do. Check your basket for cracks as this is usually the cause of the problem. I hope this helps with the problem, good luck.
Posted on Apr 18, 2010
john224
  • 1378 Answers
SOURCE: My primary circulating motor hums
The starting switch that controls the capacitors is likely the problem. If the arms are bent you can bend them back to the point they work properly. If they are damaged beyond repair you can replace the stationary start switch. If you are not familiar with these repairs you can contact a local electric motor repair shop and they should be able to help you.
John
Posted on Oct 26, 2010
Testimonial: "Thank-you very much!"
Fisher&paykel ,smart drive excellence 7 .5 ,the washing machine stopped working during the pumping out of the water.no power on the top panel and a slight humming noise
What is it? No power to panel or slight humming sound which indicated there is power? Can't be both. I would suggest that the humming sound if you put it on spin, will be the drain pump trying to go. If pump is left humming like that it will get hot & shut the power off until it cools down again. Pump hums when it has a blockage & can'y spin. Clear the blockage.
Dec 29, 2016 | Fisher and Paykel Washing Machines
I have a frigid air gallery series washer that lights up and just humms,it will not start cycle. I have checked pump and motor isn't ether one of those making humm sound
Good Afternoon Cloy,
I understand that you are getting a humming sound on your Frigidaire washer, and it will not start a cycle. I also see that you've checked the pump as well as the motor, and neither of those is making the humming sound. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine what is causing your appliance to make that humming sound and not run a cycle. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Washing Machines
Dishwasher hums intermitantly and after the wash cycle is completed
Sounds like you have a bearing going out. It could be in the system pump or the rotating washing arms. I would suggest getting ahold of Kitchenaid's customer support and relay when during which cycle the noise occurs and they should be able to identify whats going wrong.
Jan 22, 2014 | KitchenAid KUDE70FXPA Builtin Dishwasher
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
Cabrio top loader that hums initially when a load starts. i beleve this is during the water in cycle time but not sure. no error codes displayed. Washer works fine otherwise. any ideas???
Yes that sounds right a hum would be at start of cycle if water flow into was restricted in some manner and washer wasnt filling. What your is the hum the water valve makes when is calling for water yet no water from hoses coming to it.
The things to check are for blocked filter screens inside of ends of water valve on back where hoses attach to.
If you have :AQUAFLOW" brand hoses the internal stopper is hose is bad and hose should be replaced using standard hoses
Also for water coming from house pluming where hoses connect to at wall/faucet/spigot
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud humming just started during wash cycle
Humming can be simply due to a mechanical vibration when the wash pump is running. Alternatively it could be the sound of the detergent door solenoid which might be stuck.
Will need make and model number of dishwasher to give further advise. Does the dishwasher complete the cycle and drain out the water?
Feb 13, 2011 | Dishwashers
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Humming noise
humming is the motor powered up but not turning. burning smell is the motor overheating. cause may be the motor capacitor which is a cheap part. try replecing it and hope thge motor survived. could also be a foreign object in the pump impellor
Mar 13, 2007 | Zanussi 24 in. DE6744 Free-Standing...
Open Questions:
See all Aqua Flo Aquaflo Flo - Master Xp2 2 Speed 2 1/2 Hp Questions
Aqua Flo Aquaflo Flo - Master Xp2 2 Speed 2 1/2 Hp 230v Pump Pmp Aqf 061253952040 Logo
138 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
Jay Finke
Jay Finke
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
