Question about Jenn-Air JDS9860AAS Dual Fuel (Electric and Gas) Kitchen Range
Oven doesn't heat up all the way on our Jenn-Air duel-fuel range
We have a Duel-Fuel Downdraft slide-in range model # JDS9860AAP. I got a call one day that there was no electricity to it. When I got home I found the breaker at the panel was tripped. I cautiously turned it back on and the control panel lit up, the ignition to the burners work but the oven does not heat up entirely. We tried baking something and had to broil it to complete the baking. Would this be the lower element and should there be a code telling me this on the control panel.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 52 Answers
All repairs should be performed by an authorized service person. if your breakers were tripped there is a high voltage short or weak home breakers. when resetting the breakers make sure the dual breaker switches are in the on position. if the is ok check for the proper voltage is at the power outlet is correct.if it is ok unplug the range. be sure not to break the gas line. remove the rear panel check to see if the power cord power cord is secured to the power cord terminal.if the terminal is damaged do to the shortage at the terminal replace the terminal and power cord. when replacing the power cord and install the power cord restrain that usually comes with the.power cord.
Posted on Jun 02, 2017
5 Suggested Answers
  • 146 Answers
SOURCE: oven panel
First try unplugging or turning off the breaker and see what happens. If that fixes it your good to go if not you probably need a control board. Some of the boards have a fuse but no one changes it as it is soldered onto the control board.
Posted on Dec 21, 2007
  • 725 Answers
SOURCE: heating element in my electric Jenn-air oven
This is one of the most simple repairs you can make on your range. And it's so affordable that you shouldn't think about replacing it!!
Just contact us at:
with your complete model number and we provide part removal/installation instructions for you when you purchase your parts through us.
We want to get you cooking again soon, so call us asap.
We look forward to working with you! Thanks, Ella
Posted on Jan 07, 2010
  • 94 Answers
SOURCE: I get Error code F1-7 on my Jenn-Air Dual-Fuel
You might find an answer here:
Posted on Jul 04, 2011
  • 842 Answers
SOURCE: bake element burned out on
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
Posted on Jul 26, 2011
Testimonial: "Perfect! it was the high limit thermostat.Thank You for your help"
Need to reinstall Kenmore Downdraft Blower
If I can get the model # I can help you more with the removal and reinstall.
May 28, 2010 | Kenmore 59940 Kitchen Hood
Is there a vent cover for the downdraft vent. The
not that I know of but the fans on these ranges usually have multiple speeds. Try using the lowest. The fans are very strong on them. Hope this helps. good luck.
Nov 26, 2009 | Jenn-Air SCE30600 Slide-In Electric...
How to cancel f9 code
JennAir F code 9
F9 Door lock safety circuit on power relay board sensed Replace power relay board
Nov 10, 2009 | Kitchen Ranges
I have a jenn-air 30 inch downdraft electric slide in range jes 9800- I have lost the owners manual. How can I get a new one? The power was off for several hours and I need to reset the clock/day. thanks...
I have 30 inch slide in Jenn air and the black top is blistering and peeling. Jenn air replaced it one but the same thing is happening again. What can I replace this with.
Jul 13, 2009 | Jenn-Air JES9800BA Electric Range
Will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Jan 03, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ or click
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Open Questions:
Jenn-Air JDS9860AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
81 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
