Question about Electrical Supplies
I have a Schumacher SE-5212A charger and it will not charge a battery. Regardless of whether it is on the 10 or 2 amp setting the needle will drop down and the full charge light will come on in about 10 seconds. I have tried it on three batteries and it does the same thing. I left it hooked up to my lawnmower for 5 hours today and it didn't charge it at all. The battery has 9.6 volts so it was not completely dead before trying to charge.
2 Suggested Answers
  • 152 Answers
SOURCE: Schumacher 2/10/50 amp charger,125/225 amp starter
It could be an internal fuse, or that the transformer is malfunctioning.
Before any dis-assembly/internal inspection, be sure that the unit in unplugged.
Good luck...
Posted on Feb 25, 2009
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Wiring diagram se-4020 battery charger
try this web site
http://www.manualslib.com/manual/523935/Schumacher-Se-2254.html Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
I need to see how the wires go inside a Schumacher SE-1052 battery charger.
Most likely that is not the case. Battery chargers that are not really old have current sensing and dont switch on unless there is a load attached to it. A totally dead battery wont be seen by the device and it wont charge it.
Jun 12, 2013 | Schumacher SE-1052 2/10/50 Battery Charger...
How long does it take to charge CCA 7000 battery ( car ) when I use SE-2158 battery charager wih 2 AMP/12 VOLT
2amp 12 volt is a slow charge it will take about 6 or more hours. when the needle on charger is down in green to full charge its fin. hope this helps
Sep 13, 2011 | SE3010 2003010 Amp Manual Starter and...
Both Battery clips have come off of Schumacher SE-5212A Charger. Need wiring diagram to make sure I replace them correctly to the battery cable wires.
use a voltmeter. turn on unit to a low setting, place volt meter leads on broken wires one on each. if the voltage goes positive on meter. the positive clamp goes on the wire that the positive(red) voltmeter lead is on and the same for the negative.
Good luck
Jun 28, 2011 | SE3010 2003010 Amp Manual Starter and...
Electrical Supplies Logo
188 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
