Question about Sharp AR-C260M All-In-One Printer
Printing problems I'm having trouble printing with my quickbooks program. My sharp AR-C260M will only print one copy from quickbooks when I am telling it to print multiples. Any tips on what to do? I have exhausted all efforts to fix this problem. Thank you in advance!
  • 417 Answers
Make sure that the collate button is not turned on as this sometimes has the result of this fault.
Thanks J
Posted on Feb 17, 2008
SOURCE:
I have a sharp AR-M237 printer and when I try to print is telling me Error: PostScript printing not license for this printer
You need to get the correct driver for printing Post Script. You need to buy the program with the licence to print post script. Good Luck
Jan 06, 2013 | Sharp AR-275 Copier
Code dk
Your black drum counter has reached 50,000 copies. The drum has reached the end of its' rated life. You should print Sim 22-6 and see which other internal supplies need to be changed out. Drums=50K, Transfer belt and fuser=100K; paper and doc feeder tires=100K to 150K.
Sep 20, 2010 | Sharp AR-C260M All-In-One Printer
WHAT IS FUSER
A "Fuser" is a component used in laser printers to "fuse" the toner to the paper, which then gets displayed as text, a picture, etc.
If the fuser has a problem, the printing may be faint, not print at all, or if dirty, can cause streaking on the paper.
Aug 19, 2010 | Sharp AR-C260M All-In-One Printer
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Jun 18, 2010 | Sharp AR-M160 Black and White Copier
Code message
improper cartridge (destination error,life cycle error )
identification error
model error
type error
destination error
data abnormality
misc error
Nov 19, 2009 | Sharp AR-C260M All-In-One Printer
Sharp ar c260m error code f9.00 print function out of service
F9-00 is "AR-NB3 communication trouble"
that is the NETWORK PRINTING / SCANNING
EXPANSION KIT. that is the box that hands on the back of the machine.
Aug 12, 2009 | Sharp AR-207 Copier
Arc 260m network help?
You will need to use the Sharp Network configuration program. This should allow you to setup the printer for network printing. You will want to use 'manual' settings for the IP. Example
IF DHCP is used, you will want to switch to Manual and put in a 'correct' ip.
IP Address: 192.168.1.189
Subnet:      255.255.255.0
Gateway:    192.168.1.1
The Gateway will not be necessary if you do not plan to use the advanced functions to e-mail scans, and prints.
Sharp Network Administration software link
http://sharp-world.com/products/asia-doc/c/download/license_01.html?link=http://www.sharp.co.jp/print/document/download-e/utility/Sadmin.ZIP
Oct 10, 2007 | Sharp AR-C260M All-In-One Printer
Sharp AR-C260M All-In-One Printer Logo
145 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
