Question about Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television
Having trouble with red convergence
The convergence will let me go up and down but not left and right
    Sergeant:
  • 233 Answers
Your TV has gone crazy on you because your convergence IC's have gone bad.   These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.   Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go. If you need to order a resistor or two,
http://servicemanuals.vstore.ca/index.php/cName/convergence-resistors   If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!   If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you dont have one you can download it at manualuniverse.com
Hope that helps!
Posted on Jan 21, 2009
Hi in the convergence to adjust the color the red is above the plus sign in 3 spots and will not come down and they are not straight
does the blue convergence crosshairs move up and down left and right? Does the red move left or right. does the red move up at all. this might indicate a faullty resistor, bad ic or just bad convergence data. let me know i am here to help
Nov 04, 2010 | Toshiba 43A62 43" Rear Projection...
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
CAN NOT CONVERGE THE RED COLOR UP AND DOWN
this indicates to me that one of the convergence convergence output resistor has open. there is a slight chance that the convergence ic amplfer is at fault. but the fact you can go left and right and not up and down makes me feel its the resistor. IM sorry thats techy talk. do you have any electronic traning. let me know make and model and ill try to get the component number and value for you
Nov 22, 2008 | Toshiba Televison & Video
Red horizonal convergence tilts instead of adjusting evenly.
For your hitachi unit one of the convergence IC is bad along with couple of low value resistance on
the convrgence board.
Good luck
Dals123
Oct 09, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Convergence adjustment for red and blue
Press the MENU/SELECT button
on the remote control to show the
on-screen menu.
Press the CURSOR RING
RIGHT
DOWN
repeatedly until CONVERGENCE
is selected.
RIGHT
to enter the CONVERGENCE
menu.
RIGHT
to enter CONVERGE RED
mode.
LEFT, RIGHT, UP, or DOWN
to
adjust the cross image until the color
outline around it is gone.
Press the STATUS/EXIT button
to exit the menu from the screen.
Aug 21, 2008 | Philips 60P8341 60" Rear Projection...
Philips 60" hdtv. Convergence problem
what is the model number of your set and I will be able to help you with your problem.
May 07, 2008 | Sony KP-41T65 41" Rear Projection...
Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
