Question about Brother HL-2040 Laser Printer
Brother 2040 printer. Toner speckles on all the pages.
Printed pages have speckles all over. Speckles get lighter after 6,7 pages.
No lights on
  • 741 Answers
Inside the printer the last step is to melt the toner to the paper. This is done with a Fuser and it heats up to over 300 degrees, that's why the paper is hot when you take it out. If the fuser is not working properly then you will get flakes of toner. So sounds like the fuser needs to be replaced. Because of the electricity and high temperature that is normally done at either a computer repair shop or printer technician Also fusers are relatively expensive, $200-$300..
Don't forget to rate this solution befoe you log out.
D
Posted on Jan 21, 2009
  • 34 Answers
Take the toner out, and shake it. Make sure you cover the holes or you will make a mess
Everytime I have had spots or streaks this has fixed it for me.
Hope this helps!
P.s. you may want to get a cleaner sheet and run it thought the rolls.
Speckles all over the page
This is happence due to bad Drom/tonner. Please replace it.
Sachidanand
Apr 13, 2010 | Brother HL-2170W Laser Printer
The toner light will not turn off, preventing printing. I'm perfectly happy with the print quality of my last printed page. Is there a way to force it off?
A small piece of electrical tape on the right and left sides of the toner cartridge covering the little round windows will fool the printer into thinking there is still toner and let you use it up.
Jan 08, 2010 | Brother HL-2040 Laser Printer
Brother HL-2040, The drum light keeps coming on and the left side of the printed page is all black?
Sounds like the toner cart. has toner packed at one end and possibly the drum cartridge is dirty. Remove both from the printer, separate the 2 and vacuum the drum cart. - them blow it clean. Run the drum wire cleaner (purple/blue tab on front edge of drum cart.) back & forth a number of times. Blow out the inside of the printer to get out toner dust. Reinstall toner back into drum cart, then hold GO/Control button down until all lights are on, let go, reinstall toner&drum back into printer, close door. Power down - then back on. That should do it. Worst case, you'll have to replace the drum unit.
Jan 07, 2010 | Brother HL-2040 Laser Printer
Getting ink splatters on copies
That is normal with this printer. I own a Cartridge World ink and toner refilling store and we've found that the new Brother color laser machines (that take the TN-110 or TN-115) drop toner speckles onto the pages. This is because the cartridges were designed poorly. We do not recommend new Brother color laser machines for this reason.
Dec 02, 2009 | Brother HL-4070CDW Printer
Please describe your Brother HL-2040 Laser Printer problem
Yep this will always happen if your just using a replacement toner. They will be depleted faster compared to the original Brother toner.
Make sure you replace your toner with the original Brother toner.
Aug 24, 2009 | Brother HL-2040 Laser Printer
Printer HL-2040 has printed out speckled result.
Please try to use the support site here or here to help you with this problem. In particular, see this article and this page.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 20, 2009 | Brother HL-2040 Laser Printer
New Toner Cartridge Does not Print (HL 2040)
hi!  have you check you toner, it has a white strap, you need to strip it to open the nozzle of your toner. but before you do that you need to shake it first to have a sharp print out before you would strip that white strap. have a nice day
Dec 20, 2008 | Brother HL-2040 Laser Printer
Dark line down printed page
problem in your fuser assy call to hardware service provider
Feb 28, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Printing With Strange Gray Marks on Back of Paper
Sounds to me like the toner - that is the toner cartridge has the wrong toner in it. The drum should be OK - clean it up first and then use a genuine toner cartridge OR you can buy our refill kit on eBay - search for Brother HL2040 - michellem6123
Oct 16, 2007 | Brother HL-2040 Laser Printer
'Speckled' Printing
Do you have the owners manual? Did you cancel the document from the computer and turn the printer off for at least 30 secs. The speckled print and lines are usually caused by a defective toner or worn drum. Usually a drum will last for 10 thousand or more cycles. But sometimes prematurely wear out. Make sure you are absolutely using a genuine Brother OEM supply. Generics have a high failure rate. This is not a heavy duty printer. When you need a drum and toner together, it will be just as cheap to buy another low end Brother printer.
Mar 30, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
408 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
