Question about Panasonic PT-51SX30 51" Rear Projection Television
Convergence is is off
The screen looks good in the center but the sides are out of con vergnce. looks like the sides of the screen bend up.
  • 2 more comments
  • willj94 Jan 22, 2009
    thanks for the help.. goin to look at it now and see what i can do
  • willj94 Feb 11, 2009
    I am still having the same problem after replacing ic's, what else could it be.
    all electronic seem fine.. the picture still bends in at top and bottom. Will a manual covergence fix this problem? I tried to order a service manual to show how to get it all ajusted and got screwed out of money, the only sent the cover page and not the whole manual. Can anyone explain how to do the manual convergence and do i really need the service manual?
    thanks a ton for the help....Im getting more determined to fix this thing than ever just to prove I can..
    I got the icu for $20 apiece from local store that i trust. Im goin to order the service manual tonight and will look for anything I may have missed. I will let you all what happends
    thanks so much for the input
  • 233 Answers
Your TV has gone crazy on you because your convergence IC's have gone bad.   These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.   Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go. If you need to order a resistor or two,   If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!   If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you dont have one you can download it at
Hope that helps!
Posted on Jan 21, 2009
  • Josh Crager
    Josh Crager Feb 11, 2009
    Did you check the large resistors near the STK IC's to make sure they are within spec? Also, once you replace the STK's you will need to do a manual convergence to get everything lined up.
  • Josh Crager
    if the picture is still bowed, you may also have a blown surface mounted fuse that powers the IC's - If you have a service manual for the set, (and for a manual conv you WILL need one ) look for fuses, also on the board the fuses may be labeled with a F prefix, like F432 - just as a resistor may be R432 and a capacitor is labeled as C432 - of course these are just examples. Also make sure you did not make any solder bridges between terminals of the new IC's, and finally....If you got those IC's off of ebay for a really good deal - its because they are fakes, and are probably no good anyways - ALWAYS use genuine SANYOS!!! hope you get it working!
The picture bends at the top and the bottom of the screen and is blurry where it bends at
The tv have a problems known as a convergence problems,it dead.Tv have colors R,G,B lines mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
My rca tv the picture is bending into the center of the screen and the letters are double and colors are off
Press Menu then setup Look for Convergence,If you do Not See It listed then you have a Blowed Fuse FL231 on the Deflection Board.
It will be Located on the bottom left hand side Board with FBT flyback Transfomer on the right side of the FBT Look for 3 in a roll small brown looking caps ,These are Fuses, It will be the one in the Middle 0.06amps has them 1-866-925-7278
Oct 05, 2010 | RCA D52W23 52" HDTV CRT TV
Convergence is good only in the center. Also adjustable only in the center From the center out the picture is distorted and bowed.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
May 20, 2010 | RCA P52937 52" Rear Projection Television
I have a double screen , bended on the sides, like 3 D
Replace your convergence ICs they are big black ICs will have part number on them STK392-110s upgrade to 180s call Mats 1-800-628-1118
Dec 30, 2009 | Hitachi 53FDX20B 53" Rear Projection...
I had a convergence problem on my Mitsubishi WS-65711 where the red and blue was bending outward from center giving a 3D effect. I replaced the STK pack and the red and blue look good now, but now the...
green is base line center and some times is not adjustable
.Did you replace both convergance chips?
also there are 6 , 2.2 ohm res that get out of
tolarance. check them first
Jun 30, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Red lighting is off on the left and right but good in the center.
Your problem is on the power supply board if your a novice call a service center.
Apr 14, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
53UWX10B Red giving problems
Good Day,
Welcome to the world of having a convergence circuit problem. There two things you can do; get it repaired by a Factory Authorized Service Center or repair it your self. Purchase KIT 10 from B&D Enterprises, 1-800-458-6053. The kit has everything you will need except soldering equipment and experience. Good Luck, big IRISH.
Sep 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Red Convergence
Visit these sites. Convergence procedure of projection televisions are given in detail.
Mar 28, 2017 | Televison & Video
Color bending
Go into the menu and look for Screen Convergence. It may also have an auto convergance option try that first. If it gives a suto error or you cant adjust it manually the convergance IC's may be bad or a component on the convergance board.
Sep 15, 2007 | Sony KP-51WS500 51" Rear Projection...
Panasonic PT-51SX30 51" Rear Projection Television Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
