Question about Intuit QuickBooks Pro 2007 Full Version (299116)
Quickbooks quits when I try to print a previous reconciliation
I have finished a reconciliation and mistakenly only printed the summary. I need the detailed rec and Quickbooks quits every time I try to print it.
I'm running Quickbooks Pro 2008 for the PC on a MAC using Parallels.
  • 60 Answers
You need to run the file in a Premier Version. Premier Version is the only version that access the previous reconciliation.
www.cpahispano.com
Posted on Aug 08, 2010
Problems Printing Checks on QuickBooks, I can't print any checks using the QuickBooks format. Everything prints except my routing and account numbers, which I put in on when I was installing it, so what...
Routing and account numbers do not print in QuickBooks. In order to print checks you need to have checks with the account information on them, using an Intuit/QuickBooks Format. You can get checks with this format from your bank or from office supply stores.
Oct 14, 2013 | Intuit QuickBooks POS Pro 2013 with rp5800...
I am running windows 7. when i try to display the previous reconciliation in quickbooks 2011 the adobe acrobat screen opens with a smaller adobe window with a question mark and the only option i have is...
It sounds like your quickbooks installation is damaged and cross-linked to adobe.
I would backup the data. Then uninstall and reinstall QuickBooks.
Aug 19, 2011 | Intuit QuickBooks Pro 2011
Printer suddenly stopped working with quickbooks but will still work with all other programs. window states: change port assignments or reinstall software. printer is hooked up wirelessly
  1. Open the QuickBooks sample company and try to print the same form or type of form. If it prints successfully, your company data, form template, or customized report may be damaged.
  2. Reopen your company file and try to print an uncustomized (standard/default) form template or non-memorized report. If the issue occurs again, refer to Verifying and rebuilding the QuickBooks company data and then attempt to print again.
  3. If you were printing a batch of forms in QuickBooks, attempt to print a single form. If successful, try printing smaller batches.
  4. If you were able to print from QuickBooks in the past from this company file:
  5. Turn off the printer, restart your computer, and then turn the printer back on.
  6. In QuickBooks, choose File > Printer Setup and check the printer settings for the specific form you're trying to print.
  7. Click Help in this area for more detailed instructions on these settings.
  8. Ensure that you have the latest printer drivers for your printer. Go to the manufacturer's website to download and install the most current drivers.
  9. Replace the QuickBooks Qbprint.qbp file:
  10. Close QuickBooks.
  11. Rename the qbprint.qbp file.
  12. Open QuickBooks and attempt to print again.
  13. If the issue persists, repair the QuickBooks installation.
Mar 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
How do i print off a past qb 2009 premiere bank reconciliation
You have to open the file in the premier version. Only the premier version has access to previous reconciliations.
www.cpahispano.com
Oct 16, 2009 | Intuit QuickBooks Pro 2008: Windows
I can only print the 941 form in quickbooks. Nothing else.
Open QuickBooks and go to file at the top left of the screen. Click on it. This will give you a drop down list. Choose "printer set up". This will give you a list of forms. Choose the name of the form you want to be able to print while in QuickBooks and this will take you to an area to choose your default printer. Click the arrow next to the name of the printer you want to use to print your forms and then save and close the window.
May 05, 2009 | Intuit QuickBooks Premier Contractor 2008:...
My DeskJet F4280 will not print
There are three things that you can try.
1. Exit and restart QuickBooks - try printing again
If this doesn't work
2. Go to your printer setting, double click on the QuickBooks PDF converter to open the printing queue, select any jobs listed and click cancel. If there are no jobs listed or you can't cancel them.
You will need to
3. Delete the PDF converter from the printer list.
Restart QuickBooks and try and reprint.
Hope this helps
3.What you need to do is go to your printer settings and delete the QuickBooks PDF Converter
Jan 27, 2009 | HP DeskJet F4280 All In One Printer InkJet
The accountant wants copies of the bank reconciliations going back to 2002. How do I retrieve them and print them?
if you have a backup file fof the year 2002 you can reload it and print them. but be sure to backup first the new files or the prsent files you have, after printing the reload again the the latest file you have backup
Jan 14, 2009 | Intuit QuickBooks: Pro 2005 for PC
Bank reconciliation locking up, printing locking up.
In your list of printers, you will have one installed by QB called "QuickBooks PDF Converter". Do your reconcile and when it seems to lock up, open your list of printers from the control panel and open this QB printer. There will be a document waiting to print (not sure why, it might be internal to QB). Select that document and hit the delete key. That should free QB up to continue (works for me). You may need to select it and press Delete two different times to actually remove it from the printer. Finally, because it is not easy to open up Printers every time, make a shortcut on your quick launch or desktop to the Printers applet.
Dec 11, 2008 | Intuit QuickBooks Pro 2008: Windows
Intuit QuickBooks Pro 2007 Full Version (299116) Logo
183 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
