Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Indicator lights on Bissell 7920
Hi, when I use my bissell, the indicator lights which show you how well you are operating the machine are very haphazard. Sometimes it shows one red light and other times nothing; I have tried slowing the movement down and then speeding up to see if it makes any difference but nothing. Should I just assume it may be a connection problem or am I doing something wrong when cleaning carpets?
Can anyone advise please.
  • 32 Answers
According to the owners manual there is a red light that signals temperature, this light will come on when the water reaches optimal temperature, the heater may need to warm up again. Here is a link to your owner's manual.
http://www.bissell.com/images/UserGuides/7920.pdf
I hope this helps.
Posted on Jan 21, 2009
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
How to i get it to pick up the water
Check your filters. One on Water Tank Cap (looks like a screen) the other under the Flow Indicator. Turn the Flow Indicator cap counter-clockwise and remove it. Lift out the rotor and under it is the filter. Clean the filter and reinstall in reverse order. If that didn't work the contact Bissell Consumer Care at 1-800-237-7691 Hope that helped.
Oct 02, 2014 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920. Took it apart how do i align the solution valve
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fggds
Nov 23, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I take apart my Bissell 7920 ProHeat Pro-Tech
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Jul 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Change belt on 7920
heatman101
cvzncbn
Mar 29, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
I am not getting any water to come out of the floor part or tools
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Nov 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Carpet Cleaner pro heat- water doesnt come out
The screw that is located in the center of the handle, that holds the assecory hose holder must be tight. My screw was missing, put one in and cured the problem. Sounds stupid but it worked. Got this idea off the Bissell web site. Also if you have a pump belt it may need replacing.The cover is on the side of the machine. Go to the Bissell web site and look up by your model # and name of machine. There are several quick fixes that you can do yourself. Why pay for expensive repairs when the Bissell site will help you for free. Good luck.
Jun 28, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bex Bissell Pro Heat 7920-E
Remove the cap for the flow indicator, then there 6 screws to remove to take off the top, before removing the top, turn the smart mix valve to about the half way point so the piston won't fall off. When you are ready to re-install the top cover, just before pushing it all of the way down, turn the smart mix valve to the water only setting, then push it into place, re-install the screws and the flow indicator parts.
May 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
96 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
