Question about LG Televison & Video
Antenna option greyed out on lg45lf2510
Antenna option suddenly not available, although antenna plugged in.
3 Suggested Answers
Drummernick
  • 440 Answers
SOURCE: antenna setup for digital signals is grey and not available
is scan for chs lit up in options scan 1st ok
Posted on Feb 11, 2008
fuckyoupenis
SOURCE: Can't get anything over antenna
need help to hack and get good signal on my TV antenna
Posted on Jan 23, 2010
Functions greyed out
Greyed Out Menu Options
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - Home > Setup & Installation > Greyed Out Menu Options Share on Google+ ... The menu options you have access to on many Samsung TVs ...
Antenna menu is grayed out - Forums - CNET
www.cnet.com > Forums > Samsung
CNETApr 21, 2013 - I have an HD over the air antenna going into my Samsung TV. However, the antenna as well as the Plug in Play menu is grayed out and can't be selected. Any ide... ... I think I might do 1 of the these two options. 1. Buy a new ... Samsung Support for Smart TV is terrible
Jun 11, 2015
TV Picture settings greyed out?
Sep 22, 2013
Samsung Smart TV update problems
Aug 29, 2013
Grayed-out menu settings with LN32A550
May 31, 2009
More results from www.cnet.com
Why is some options in TV menu grayd out? - SamyGO
Dec 25, 2015 | Televison & Video
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Cant get radio to play stops on station wont pick up antaina hooked up
Check if the antenna male plug is completely plugged into the antenna port of the car stereo.If it is plugged well in the car radio but don't pick stations then your antenna cable is bad.You need to install a new set of antenna,available at any car audio supply.
Jan 30, 2011 | Sony Car Audio & Video
I want to use an antenna on my emerson 2703 flat screen, but the menu doesn't have an antenna option . how do i get the antenna to work?
either you plug the antenna in ... or you cant use an antenna and have to buy another which allows antenna
Feb 17, 2010 | Emerson EWF2703 27" TV
The wires on the power/antenna plug on my 1996 ford fiesta are.large brown,brown/yellow,grey/yellow,large yellow,brown&red.which is ground,12v+,memory & power antenna?
Use a tester to figure out these wires. large yellow is typically power, large brown is ground, check the other 3 with a tester. turn radio on and see which one lights up, this is your antenna or trigger wire.
Aug 23, 2009 | Car Audio & Video
1999 Mazda 626 antenna won't go down, hums.
Spray the antenna with a spray lubricant (WD40) or similar. and let it sit for an hour.
Then start the car and see what happens.
The antenna is probably full of filth or corrosion..
If that doesn't work take the side cover off the trunk on the side where the antenna is and you will find a plug in electrical connector near the motor that winds the antenna up and down, pull that plug out and the antenna will stop trying to wind itself down..
May 09, 2009 | 1999 Mazda 626
Gps garmin nuvi 660
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Oct 26, 2008 | Garmin Nuvi 660 GPS Receiver
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
Televison & Video Logo
247 people viewed this question
Computer Repairing
Computer Repairing
