Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
"How do I transfer individual files archived on my SimpleDrive from old PC to newer HP Windows 7 laptop?"
Do I just hook up the SimpleDrive to the new computer, install form the software from the original CD? Will I need to download new drivers? Do I use "Restore from Hard Drive" to select individual document or photo files archived from the old PC to transfer them from the SimpleDrive Backup to a folder on my Windows 7 PC?
  • SimpleTech Master
  • 27,725 Answers
Connect your simple drive to the computer with the usb and power lead if applicable.
Click start all programs accessories open windows explorer my computer you should see your drives C: usually your hard drive D: your cd dvd drive and your usb drive E: or F: click to open it from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to your usb drive disc then drop them Hope this helps.
Posted on Jan 10, 2013
SOURCE: Simpletech 320 GB
how do you open it?
Posted on Mar 05, 2008
MAXTRIXKHAN
  • 45 Answers
SOURCE: external hard drive
ya yiu can do it only you need is to download the drivers from the homesite of teh type of hard drive u r using
u hav not mentioned the name her so just simply try by searching google for the driver
Posted on Jul 28, 2008
ashishd19
  • 35 Answers
SOURCE: SimpleDrive I cannot retrieve files; Model No. 96300-40001-001
I feel the problem can be something else as well.
The message "Photo Gallery can't open this picture because it might have been deleted or is in a location that is not available" can be because the Photo Gallery program that you use to view pictures in your computer.
First, try this, right click on the picture and click on "Open With". This will give you a list of all programs.
Here, you can select "Windows Picture and Fax Viewer" and place a check in the check box below that says "Always use this Program.." and click OK. See if this works.
I would also like to know if you are able to open other files on this drive except picture files.
Also, the document that you are trying to open, what's the file type for this document.
You can try one more thing that will help us to isolate the issue.
Please note the next step we are going to do is just a diagnostic step and we will revert back to the original settings after this step.
  • Go to Run and type MSCONFIG and click OK
  • Now on the new window that comes up click on a tab at the top that says Services
  • At the botton check the box that says "Hide All MS Services" and click "Disable All" on right
  • Now go to last tab at the top that says "Start up" and click "Disable All" at the bottom.
  • Now click OK at the bottom.
  • It will ask if you want to restart or exit without restart.
  • Click on Restart.
  • Now your system will restart.
  • Once you come back to Desktop you get a message that says "Sys config was used to make changes to your system.
  • Click OK here and it will again open the Computer Management window.
  • Again go to the Services tab, check "Hide All MS Services" and this time click "Enable All"
  • Next go to the "Start up" tab and click "Enable all" here as well.
  • After this, click OK and this time click "Exit without restart" (now settings will be restored whenever you restart the system)
Now go ahead and try to open your pictures and documents to check if its working.
If not, then try the fixes provided by other friends above.
Even if it works after MSCONFIG, that will show that there is some other program/spyware creating this problem and in that case try uninstalling any recent programs you installed and Run the complete virus and spyware scan.
Please let know if you need any further help.
Posted on Nov 21, 2008
SOURCE: USB external hard drive driver
If you go into Computer Management and go to Storage > Disk Management. You'll see the partition there. Right click on it and assign it a drive letter. You will be able to access it from there.
Posted on Jan 30, 2009
  • 111 Answers
SOURCE: i need the drivers for instalation of 500GB
Hope this helps
http://www.simpletech.com/support/support_downloads.php
Posted on Jul 15, 2009
Tip
How to transfer your old files to Window 7
Before beginning i recommend performing a full backup so that if anything goes wrong you can roll the system back to working state.
1. You might have a large number of files on your computer that you've either downloaded.The chances are you've also not accessed many of these files in years.
Take time to make an assessment of which files you actively use. In many cases, you'll find that you can free up large amounts of disk space by simply archiving old files. Do this now to clear space and you'll save them later on.
2. Download Microsoft windows easy transfer from http://tinyurl.com/windowsET. Select the correct version depending on whether your old windows installation is XP or Vista, and 32-bit or 64-bit. If your not sure with vista, click start ,type system and click system in the programs list. In XP, click start then Run.Type system.cpl and press Enter. In each case it will tell you if your current version is 32-or 64-bit.
Once downloaded , double click on the easy transfer file and follow the installation wizard.
3. Run windows Easy Transfer from the start menu. The initial screen tells you what it can do. Click Next to continue. The next screen asks which transfer method you want to use. If you're transferring files using and external device, click the bottom option. Click Next again, and you'll be asked which computer you're using, click it.Windows Easy Transfer now builds a list of your files and settings. This process may take several minutes.
4. Easy File Transfer will identify the data it plans to transfer for each user account, and also from shared locations. Review files using the Customise buttons. This displays a sub-window,allowing you to select what you want transferred. If you need to remove files from the list,click advanced.
You can then deselect files by un-ticking the check boxes.
Click next, enter password if required, then click next again to select a transfer destination. The program creates an archive and tells you where it's stored. You can now exit the wizard.
5. Install Window 7 using the disc supplied. When complete, insert your USB drive and open it to display its files. These are stored as a self-extracting archive, so there's no need to install easy files transfer on windows 7.
Double-click the files from old computer. After a few minutes you'll be presented Whit a similar window to the one you saw earlier when you created the archive, but this time you're choosing files to load to a new computer. You can click Customise to omit files, as before.
6. Click Transfer to start loading the files on to the new computer. To prevent file corruptions or access conflicts, Windows 7 deliberately hides the menu bar to prevent you from using the PC until the transfer is complete.
Finally, click on the option to see the files that were transferred. Clicking the Program report tab also lists any third-party applications, such as adobe reader, that windows 7 thinks you'll need to install to access your files.
We are done now wish you luck' and please leave comment and feedback.
thanks
on Apr 17, 2010 | Computers & Internet
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
How do I transfer my music library to a new computer using the simpletech 1tb simpledrive?
itunes requires that you authenticate a computer with your log in account simply log in with old computer, save the itunes library to ext drive
then de authenticate the old computer
log in with new computer and authenticate it
then bring the itunes files on to new machine
takes a while but it works
Jun 14, 2012 | SimpleTech 1TB HITACHI SIMPLEDRIVE IIUSB...
I just purchased a new laptop that has windows 7. How do I transfer my accounts and files from my old one that uses windows xp?
From the windows 7 computer, Start, Accessories,System Tools, Windows Easy Transfer. Follow the onscreen instruction. Note both system must be on the same network.
Aug 08, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Flash drive transfer
yep ... just use thew copy feature ... not cut
May 02, 2010 | Computers & Internet
Older copy of alohabob will not update and will not work with pre
Unfortunately, AFAIK, Microsoft first bought the company then moved its WETC (Windows Easy Transfer Companion) off from its Beta. I am afraid your version now is just too old to be effective even if you will circumvent updates problem
You can consider to buy PCMover or MoveMe
Or you can try a free beta of PickMeApp - a tool for programs transfer. In combination with Windows File &Settings Transfer Wizard it can be used for a move to new PC, though it works best with individual programs.
Jan 03, 2009 | Eisenworld Computers & Internet
External hard drive
Jul 28, 2008 | SimpleTech SimpleDrive 160 GB External USB...
I am trying to transfer files from an HP with Windows 95 to my HP Laptop with Windows Vista. My old computer tells me that I do not have the proper driver installed. What to I need to do to install a...
You cant transfer files from your old computer with Win 95 Using windows easy transfer which is a file transfer software in vista . If you want to transfer files then you have to copy them on a cd or dvd then paste them to your new computer . It will take a lot of time . Call a computer expert and tell him that you want to transfer the file from your old computer . He will do that easily .
Please rate me .
May 14, 2008 | Computers & Internet
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
111 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
