Question about NEC DSX 22 Corded Phone
Can I listen to the on hold musuc from my phone
How do i retreive my voice mail messages
hold the #1 down until it dials your voice mail for you, then listen to messages. push 7 to erase one & push 9 to save one after you listen to them. Phone does not come with voice mail set up already, so if this is a new phone for you, you will have to dial 1 & hold button down until it rings & it will walk you through setting it up
Feb 23, 2015 | Tracfone Wireless LG 440G
How do I delete music off of my iphone
Which IOS you have. Best way is when you sync. it on itunes just uncheck the musuc you want to delete then click on apply.
Sep 23, 2014 | Apple iPhone Smartphone
What do I do to listen to messages as they are being left by caller?
just dial your voicemail box number to listen to voicemail messages left by callers..usually the #1 key is the voicemail dail key..press and hold the #1 key to have your phone dial the voicemail number..(if voicemail is activated and set up on your phone)
Sep 09, 2011 | Cell Phones
Musuc player not working. I want to re install the os of Nokia 3110c. pls hlp me.......
Here is the complete procedure read carefully and follow
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 06, 2011 | Nokia 3110 Cellular Phone
How do i listen to the radio in my phone
Hi
For you to listen to radio on your NOKIA phone you must connect the head set.
Hold down the * button and it will go straight to your radio. You can now search for station by pressing the option button and scrolling down to search.
Thanks
Aug 11, 2010 | Nokia 5230 Cell Phone
I bought a verizon phone had it flash so i can us it with metrol pcs it has a mp3 but when i put the the little memory card with musuc it tell me there is no songs what do i do next?
Your music should be in the My Music folder of you mem card (and not in individual folder). When I synced my music from winamp or media player it puts the music in folders by artist. If the music is like that it might not read. thats what happened to me. i had to copy the files directly to the my music folder. and your phone should be able to read wma. mine does. I've had this Krave since mid august. this is how i got the music to play.
Sep 22, 2009 | Motorola Mobility Kraveā„¢ ZN4 Cell Phone
Samsung g600
you can press and hold the #1 key on your phone it will automatically activated the VM and just listen to the prompts.
Mar 26, 2008 | Cell Phones
NEC DSX 22 Corded Phone Logo
14 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
