Question about Brother IntelliFAX 4100 Laser Fax
Hello...i have a intell fax 4100e...it was working fine...but i have recently had problem getting my phone messages to go to mail box...they go to fax...i have a second line/ring with a separate number for my main line. there are buttons on machin'e MODE==saying fax===tad==fax tell. i understand i should have it on fax/tell NOT fax -- but the calls keep going to fax on main line = not the answering service. help.
    Champion:
  • 320 Answers
Try using tad which stands for tle. answer device
Posted on Jan 24, 2009
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
I can send faxes but can't receive. Phone company says lines are fine.
look up the manual to your specific fax machine. There are different settings and the manual will tell you what to put it on in order to recieve faaxes....good luck!
Aug 06, 2012 | Brother IntelliFax-4100e Fax
We have the Brother Intellifax 4100E. It was working fine up until last week. Then it started not receiving faxes. We can copy, and send faxes, and receive the confirmation. I have checked the mode button...
Try calling the fax machine from your mobile and see if it picks up or if anything shows up on the screen of the fax machine. Is it possible that you have plugged the fax machine into the wrong telephone line? Try sending a fax to your mobile phone and see that the number is correct.
Mar 07, 2011 | Brother IntelliFax-4100e Fax
How do I change the modem speed on the Intellifax 4100e
You can't, plus it won't work on a digital phone line anyway
May 27, 2010 | Brother IntelliFax-4100e Fax
I have a Brother IntelliFax-4100e fax that speed dial button 04 needed to be changed when we changed our phone system to include a 9 at the beginning of the number. Did that, it was 'accepted', but still...
go into menu, then to fax (hit set) then one touch speed dials (hit set) then hit the 04 one touch button and it should show you what is programmed. You can hit number 1 to change, type the number with a 9 in front of it(ie. 9+1+area code+7 digit number) then hit set and program a name for the number, hit set until the fax beeps to accept the change. You can test it with a blank cover sheet. That's how I have mine at work set up and it works fine. Hope this helps.
Jan 29, 2010 | Brother IntelliFax-4100e Fax
How do you shut off the 4100e?
There is no switch. Most fax machines are expected to be left on in case a fax call comes in the middle of the night. If that's not a concern in your case, unplug the machine. If the plug is hard to reach under a desk or something, you might want to get a power strip with a switch on it. As long as you're at it, get one with surge protection for both the power and phone lines, and your fax might be saved from sudden death in the event of some guy driving into a power pole down the street.
Dec 22, 2009 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Nov 07, 2009 | Brother IntelliFax-4100e Fax
WHAT DOES NG MEAN ON THE FAX CONFIRMATION. I HAVE THE BROTHERS INTELLIFAX 4100E
Noise or other problems on the phone line. If inside wires and box checks out, call the phone company to check line to the house.
Let me know if I helped.
Oct 26, 2009 | Brother IntelliFAX 4100 Laser Fax
Busy Signal
DO YOU HAVE DIAL TONE ON THE PHONE? IF YES, YOU MAY HAVE A BAD PHONE BOARD. MAY NEED THE HELP OF A SERVICE CENTER. BROTHER TECH
Jan 12, 2009 | Brother IntelliFax-4100e Fax
Brother IntelliFAX 4100 Laser Fax Logo
81 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
