Question about Humidifiers
I have a Walgreens Ultrasonic Humidifier 2055 that hasn't been used in 1 yr. It worked before and now when I set it up the red light comes on and no mist comes out. The manual does not provide an
I haven't used my humidifier in 1 yr and now when I need it the red light comes on. I followed the set up directions in the manual and nothing happens. The owners manual does not give an explanation for the red light being on. Does this mean the unit is broken or just in need of servicing? When I put the unit away I cleaned it very thoroughly so I don't understand why it's not working now. Please help. Thank You. Elaine
  • 7 Answers
SOURCE: Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See http://www.fixya.com/support/t253969-cleaning_instructions
Posted on Feb 12, 2008
SOURCE: Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
Posted on May 30, 2008
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
freetek
  • 5568 Answers
SOURCE: Need parts for Sunbeam ultrasonic
I see you have been waiting on a response for some time and I suggest you contact Sunbeam (if you haven't done it already) at their website for Canada:
Sunbeam Canada Customer Service
big-dog420
  • 124 Answers
SOURCE: no owners manual with holmes cool mist humidifier
This page has 18 pdf user manuals they are only 1-2 pages each open them in adobe reader till you find the one you need wish i could be more help
http://www.holmesproducts.com/Manuals.aspx
Posted on Nov 15, 2009
Is there a filter I need to replace in the Walgreens humidifier model # 2055? Tks
Most humidifier's have a filter I would google make and model along with filter replacement you should be able to pick up a on line manual to get correct size and how to change it .
Jan 03, 2018 | Walgreens Humidifiers
How do I fill a Walgreens ultrasonic humidifier model NO: 2065?
Lift the clear tank straight up off the base. Turn it upside down and turn the filler cap clockwise about 3/4 of an inch. It should lift out. Fill and replace the cap and put the tank back on the body of the humidifier. Make sure that the seal to the filler cap is seated properly.
Mar 14, 2017 | Walgreens Humidifiers
Walgreens Dual tank humidifier 2035 stopped working
I've never seen this model, but it would suggest that the unit is unable to function due to either an electrical failure or needs a serious deep cleaning (esp.the part that interacts with the water to form mist.) I would completely empty the unit and clean it, then partly fill the reservoir with 50/50 mix of white vinegar and water and let it sit for 24 hours (possibly longer) to remove any deposits. (Doesn't take much build up to kill the ultrasonic process). Other than that, try calling the manufacturer and see what they will do for you. (Think it's Sunbeam).
Dec 21, 2015 | Walgreens Dual Tank Ultra Sonic...
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
Bought this last year and don't have the manual. Can't remember how to fill the removable water chamber.
I would call or write to the warranty company: BW Consumer Services, POBox 8134, Elburn, IL 60119. 1-877-365-6274 and ask for the Walgreens Ultrasonic Humidifier 2055 user's manual. That is the information spelled out in the original users manual that come with the product.
Oct 18, 2011 | Walgreens Cool Mist Humidifier Humidifier
What is the box with lightning bolt inside? turn on humidifier and just the orange light above this comes on but humidifier not working?
I looked at the Owners Manual for your humidifier online, but could not locate what you described.
However, it is manufactured by Homedics and you can contact their Customer Service Dept @
800-466-3342 Mon - Fri, 8:30a - 5pm ET for help in solving your problem.
Mar 07, 2011 | Walgreens Cool Mist Ultrasonic 2 Gallon...
Humidifiers Logo
680 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
