Question about AOpen Slot 1 AX63 Pro (91.87810.611) Motherboard
MONITER PROBLEMS I have a Ax 63 pro motherboard it powers on but no moniter what do i do
  • 34 Answers
There is are many things that can cause this, try the following:
  • Disconnect any extra items you may have hooked up, disconnect power connectors too (except mobo and fans) (HDs, CD/DVD drives, extra cards except the video card)
  • Remove all but one stick of ram, then rotate the ram in several slots, and swap out that chip with others if it doesn't boot yet (sometimes bad ram will cause your error)
  • Re-seat your CPU
  • after all this also reset your bios, this can be done by unplugging the computer from the wall and removing the battery from the bios, or on some boards there is a jumper to do this (See your manual)
I hope this helps.
Posted on Jan 21, 2009
My computer often fails to start. even if the hard disk is running my moniter and keyboard doesn't show ant sign of power signal and the moniter screen just remain blank with power led of moniter blinking
Note: make sure that the computer is turned off before removing the RAM from the DIMM slot. Hope this helps.
Sep 27, 2009 | MSI 845 PRO Motherboard
Moniter doesnt show anything
ok check you video driver because if your moniter is working with other computers then that could be what it is but let me know if anything else happens
Nov 07, 2008 | Soyo SY-K7VME Motherboard
Qdi motherboard only 200watt power supply hooked up and the 4 12v pin is not hooked up computer turns on but moniter doesnt
you need min 250w power supply with the right connector.
do not try to splice any of the power wire. it will work but you will get burn later.
Oct 02, 2008 | Computers & Internet
Help about driver and softwera
which monitor you are using ...?
you mean you need the graphics driver or the monitor driver itself reply clearly i will get you the links...
and also tell me the model of the monitor if it is monitor driver & motherboard details if it is graphics driver ....
i am always here to assist you ..
reply me soon
Apr 07, 2008 | Mitsubishi Diamond Pro 900U 19" CRT...
Male moniter plug on both moniters(every one in the world) and motherboard
That Male connector is a serial port not video, you need to get a video card and plug the monitor to this card.
thanks for rating
Jan 10, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
No display on moniter but cpu is running
change the RAM(RANDOM ACCESS MEMORY) of your pc.
Dec 12, 2007 | Intel Motherboard
Moniter problems
Hi, have you used the same motherboard in the two towers? sounds to me like you may have a couple of faulty capacitors on the board. Open the case and study the capacitors closely [with a magnifying glass if need be] capacitors fail very often when heated. they are the round components that sit in sets of 5, 6, or more in a row on the board. if any are bulging from the top or bottom, then its time for a new board. Regards mistyman
Sep 01, 2007 | OWC Mercury (OWCME4121330L2S) PowerPC G4,...
AOpen Slot 1 AX63 Pro (91.87810.611) Motherboard Logo
57 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
