Question about Amana ALG443RAW Gas Dryer
Dryer drums makes noise when turning
When you turn on dryer and the drum turns there is a whining sound on the back side of the dryer?What is wrong with the drum?Can you oil it or grease it?
    Problem Solver:
  • 18 Answers
What brand?
Posted on Jan 21, 2009
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Amana electric dryer whining when started
Is ther anything caught between the drum and the back of the dryer. run you finger around the back edge of the drum inside do you feel anything caught
Feb 02, 2014 | Amana Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
The drum is hesitating and making a whining sound
sounds like the belts are badneed changing
Feb 19, 2010 | GE Dryers
When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
I've just purchased a used dryer, and unfortunately it makes a steady whining noise while it's running. It's driving me nuts.
sounds like youhave something in the blower wheel. if your dryer has a front removable lower panel with a putty knife on the left and right sides 1 inch in from the sides slide putty knife in to release catches. two screws hold the bower housing on then you can look at blower wheel. if it doesnt have removable panel then youmust access it from the back access panel then on left side take out 4 srews that hold blower cover on and pull back as far as youcan without bending top and look inside with a flashlight.. remember always unplug unit
May 27, 2009 | Whirlpool LEQ9858L Electric Dryer
Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
Noise from dryer
drum has worn drum bearing dryer top AND rear panel must be removed to acess the rear of drum to replace drum
Sep 24, 2007 | Zanussi TC7102W Electric Dryer
Amana ALG443RAW Gas Dryer Logo
261 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
