Question about Linksys EtherFast Cable/DSL Router
I have a Linksys router (BEFRSR41) that will only connect
From port #1 of the four ports. I called Linksys tech supoprt and they won't even speak to me about it since the router was bought a few years ago. Any thoughts (other than..I don't know why Linksys won't stand by their product).
  • ramosrich May 11, 2010
    Greetings, pls explain your problem more. I need more info to be able to troubleshoot your issue.
  • Linksys Master
  • 4,338 Answers
I would suggest a Linksys reset:
This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Try the other ports at this time.
If you still have problems:
Once the router has been reset, you can log in to it.. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
There you can look around the setup pages and see if any errors are reported. Also make sure that it is set for DHCP.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 18, 2009
My Linksys router was working fine with my Compaq Presario until I upgraded to HP pavilion slimline with Windows 7. The slimline has only one Ethernet connection; the Motorola modem also one; and the...
Connect your Linksys router to your Motorola modem through the internet connection on your router. The ethernet ports on your router is for your PC's. The 4 ethernet ports on your router means you can connect up to 4 PC's hardwired to the router. You may also wants to contact Linksys Technical Support Team to assist you on the configurations of your Linksys router.
Aug 31, 2011 | Computers & Internet
Can't Connect more then 2 devices, on my Linksys Wireless Broadband N router. Called Linksys tech support not helpful, the other devices are coming up with Parental Controls.
Can you explain about your network diagram, what type of connectivity you looking????
or you can connect your devices as per below:
1. ISP cable -> Router1's Broadband port
2. Router1's LAN1 -> Router2's Broadband port
3. Router1's LAN2 -> Router3's Broadband port
Mar 31, 2010 | Linksys Wireless-G Broadband Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Linksys Wireless WRT54G Router Won't Connect
Here's something you can do.
First, power off the modem and the linksys.  Then swap the yellow cable with the blue cable (this time, connect yellow cable to port 2 of Linksys)
Now, turn on the Modem first... wait about 1 minute, then turn on the Linksys.
1. Log into the router and go to "Status" tab.
2. You should see something called Internet and under it Configuration type.  If all you see is 0.0.0.0 without a gateway address, it didn't work
3. You can also see 2 buttons at the bottom of the screen.  Click on "DHCP Release", then "DHCP renew"
4. look at the configuration type and see if it is no longer 0.0.0.0 Then try connecting to the internet to a website you have not visited (do not try the same websites as before when you initially tested).
Jun 29, 2009 | Linksys Wireless-G Broadband Router
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
The port of Linksys Wireless-G WRT54GS Router Linksys Wireless-G WRT54GS Router
What do you want to know about the ports? The one separated from the other ports is the Internet port. that is where you're going to connect the cable from your modem. The other four are the ethernet port where you will connect the computers.
Jan 22, 2009 | Linksys Wireless-G WRT54GS Router...
Ethernet cable lites don't lite up when a cable is inserted in any of the four ethernet ports. I have Linksy-G router. I can't seem to communicate with my other computer on my network setup. Donald...
If the light wont lit on the port where that cable is connected , that can mean the cable is bad or the router ports are bad so if you have an extra cable better try it and if that work so the problem is the ethernet cable but if still have the same result the problem is the ports on the router and better call Linksys tech support for that this is the number 800-3267114.
Hope that helps.....
Aug 11, 2008 | Computers & Internet
Ps3
Are you going to connect your PS3 wired to your router or wireless?
1. check first if ps3 is working behind rca modem.
2. then connect a pc directly to your linksys router
3. open configuration page of linksys by typing your gateway on your browser. (usually it is by default 192.168.1.1)
4. go to applications and gaming tab
5. you'll find there port forwarding..key in your number there
> i guess your numbers are like 88 and 3764 (something like that)
6. if your trying to connect your playstation wirelessly, you need to know your wireless security (if your router is secured).
> go to wireless tab and look for wireless security
> get your key
7. go back to playstation and try to view your wireless network
> connect and type in your key
Jan 25, 2008 | Linksys Wireless-G WRT54G Router
Connecting my router
Ok, so the ethernet port on your DSL or Cable modem has to be connected to the WAN port on the router first and foremost. Then I would suggest that you connect the ethernet port on the laptop to port 1 on the router, and attempt to log in that way. Bring up your browser (Internet Exploder, Netscape, etc.) and type 192.168.1.1 (if that doesn't work try 192.168.0.1, Linksys switches it up) in the adress bar... and ensure that you can get in that way. Then try surfing the web to see if it connects correctly... although you may need to speak to your Internet Service Provider to ensure that they are allowing your MAC Address to connect to their Network... the one under the WAN settings, NOT the LAN settings. It should look like this... MAC Address: 00:01:81:52:3f:99
Sep 08, 2007 | Linksys Wireless-N WRT150N Router
Linksys wrt54gs cant connect..
hi try this before you hit the reset botton. Check if Windows XP firewall or 3rd party firewall are blocking the pings, and temporarily disable them just to be sure. The WRT54GS has a feature called "AP Isolation", It's on the "Wireless -> Advanced Settings" page. You won't need it for home use so turn it off as well. Last thing, do a firmware upgrade. Hope it's helps Good luck.
Mar 20, 2006 | Linksys Wireless-G WRT54GS Router...
Linksys EtherFast Cable/DSL Router Logo
113 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
