Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer making a squalling sound during spin cycle
Washer making a squalling sound during spin cycle.
    Novelist:
  • 101 Answers
It might be your motor coupling going bad. The motor coupling sits between the motor and the transmission and is what spins the transmission when the motor starts. It's a cheap little part made out of plastic and housed in a rubber gasket. What you can do to check it is this. Unplug the washer and tip it back. Put your hand between the motor and transmission in the small little crevasse. You will feel the motor coupling between there. You can turn it by hand and as your turn it feel to see if it feels melted or if there are any soft spots. Feel if there are any weak areas or if it feels torn at all. It may feel fine though, it could be that one of the teeth on the inside are broken which you won't be able to tell unless you remove it. That's easy too, two screws on the two black clamps that hold the motor up. Remove those and pop one of the clamps off with a flat head screw driver. The motor will come right off and the motor coupling will come with it. If it's damaged just get a new one. They cost around 10 bucks and are common enough that they should be available at any local appliance repair shop. Let me know if you have any other questions and let me know if this was helpful to you. Good luck.
Posted on Jan 22, 2009
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Kenmore 22622 washer tub will not spin during spin cycle, burnt smell
Sounds like the belt between the motor and the tub is slipping or the tensioner spring may have failed.
Dec 14, 2013 | Kenmore 22422 Top Load Washer
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
I have Kenmore 80 washer and for the last few weeks it has been making louder noises with a little whinning sound during the spin cycle, now it simply will not spin, but it does make awhirring sound on the...
first off empty the washer and check the 2 belts about a foot, from the bottom,to see if there still intact,,,also could need some grease to free up seized parts...gl
Mar 28, 2009 | Kenmore 22422 Top Load Washer
Washer making noise during the spin cycle
Hi!!! it looks like your motor coupler is failing..Good luck..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
