I have a visio 42 inch LCD TV. I took it apart and found 5 of the back light tubes a broken how can I find replacement tubes?
  • 933 Answers
Well first thing, they are measured mm. You will need to get the length and thickness in mm. You can find them on Ebay or several other outlets. Just google CCFL suppliers and you will find several. Expect to pay around $15/bulb. I'm sure I have those bulbs in stock as I recycle a lot of sets. I could make you a good deal on them but would have to find a shipping box.
Posted on Jan 11, 2013
SOURCE: Visio 42 in Plasma turns on but no picture
Just had the same problem and determined it was the primary power supply board. The TV has a primary and secondary power supply. The secondary controls the on/off and audio. The primary controls the picture. If this is shot, you will not get a picture but will hear audio. I had to call Vizio and have them send me a new power supply board ($150 + SH). Not too hard to install yourself. Hpe this helps!
Posted on Aug 22, 2008
  • 668 Answers
SOURCE: How to replace lcd tv bulb
Most of those models you replaced them through the front. The lower front panel pulls off. Some models have a knob that must be loosen on the back of the set at each end. Once the front panel is taken off the Lamp door is easily accessed. The new Lamp from Sony will come with the proper Wrench to remove and reinstall lamp.
Hope this helps,
Skyassoc
Posted on Jul 04, 2009
1fastbob
  • 301 Answers
SOURCE: 42 inch lcd tv.its a rca. the screen is damaged.
There is NO picture tube on an LCD set. If the screen is damaged it will make more sense to buy a new set rather than attempt a repair.
Posted on Nov 13, 2009
  • 11 Answers
SOURCE: sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Posted on Apr 07, 2010
  • 17 Answers
SOURCE: Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Posted on May 13, 2010
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
How do I know if I need to replace the main board?
Vizio TV Repair - How to Install Vizio LCD Motherboard ...
? 6:21
https://www.youtube.com/watch?v=B_ae3f7C3jQ
Feb 20, 2012 - Uploaded by Brady Smith
Learn how to replace your LCD Visio TV motherboard and hear a few facts ... ANYBODY KNOW HOW TO FIX OR WHAT NEEDS TO BE FIXED IF THE ... I have found that I need to replace themainboard in my vizio 42 inch. .... hey, man. can you help me out? i got a VIZIO E3D320VX from ebay brand new.
Vizio 3632-1512-0150 Main Boards Replacement for ...
? 2:48
https://www.youtube.com/watch?v=a_8URZW356E
Dec 6, 2012 - Uploaded by ShopJimmy.com
Top Common Vizio LCD TV problems for bad Main Unit Boards:... To be best prepared to replace the Main Board inside of yourTV, you will need the following ... If you have any further questions regarding your repair, simply post a ... i can see on one of the small black squares (sorry i dont know what they ...
Vizio TV Repair - E601i-A3 Main Board Replacement for No ...
Dec 08, 2015 | Vizio XVT473SV 47 in. LCD HDTV
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
We just bought a Visio LCD TV 42 inch. The problem is with the volume going up and down on its own. We took it back and got another Visio and it's doing the same thing. Do you think the problem is...
Hello there, the probability of 2 Vizio LCD's having the same problem is quite abnormal. The problem is definitely from the cable box as LCD TV's are usually factory tested to ensure that such problems dont exist in the unit. Check the cable box and also check the cables with which the cable decoder is connected to the TV. This is where your problem is from.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 06, 2011 | Vizio Televison & Video
Tv is turning off and on
There no lamp in the LCD tv only CCFO floorescent light tubes.U can't reset or adjust those CCFO floorescent light tubes.Those CCFO floorescent light tubes are design to work as a whole LCD screen for the tv that it.The tv power supply board is dead.That the board where the power a/c cord plug into it.That the power supply board,it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.On the board u said u see flashing blue light,searches all around for those dead leakages capacitors,they alway bulges up on it tops or puff up on it tops.Replaced those dead capacitors or replaced the whole board.This actions will get the tv power stable again and work.
Jun 03, 2010 | LG 42LC2D 42 in. LCD HDTV
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Jul 25, 2008 | Zenith ZEN700 Remote Control
Open Questions:
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
