Question about Sony MDR-RF810 wireless headset SONY
Hey! I have a problem with my sony MDR-RF81 headphones....when the bass is to loud...there volume is droping...when I listen to skirllex for example...the volume is high or low...but when the bass starts...they go very low...like a whisper...and I don't know why.
    Problem Solver:
  • 7 Answers
Hey there, the problem with your sony is not a hardware problem, the headphones are completely fine, its the amount of bass you are putting into the headphones, there are two solutions to this, if you're using a mobile device (Apple, android etc...), go to your app store and download an equaliser e.g poweramp, with this, you can adjust the sound going through to your headphones using the built in equalizer (usually 5-10 bands, research this if you have no knowledge of equalisers), you can use this to turn down the bass frequencies in the sound, or the only other thinkable options are if you are already have an equaliser in use, turn it down, because putting all of the bars to the top makes the sound horrible, research on some suggestions for equaliser presets (another word for equalizer settings), or just turn the volume down.
the reason this happens is because bass naturally overpowers treble, and if it is too loud, the treble and mids will be significantly quieter, headphones are a menace for this, so all you have to do is tweak the sound a little (using an equaliser) to find that perfect balance between the different elements of sound.:-) :-)
Hope this helped mate :-) :-)
Posted on Nov 18, 2013
  • Rikki Paul
    Rikki Paul Nov 18, 2013
4 Suggested Answers
SOURCE: Where can I find replacement battery BP-HP550???
SONY website does not have this battery in search results. Is there any other equivalent?
Posted on Feb 04, 2010
  • 6 Answers
SOURCE: i need rechargeaable
Since many Sony headsets use the BP-HP550-11 battery pack, I assume your battery pack is the same. If not, I assume whatever battery pack your headset came with, it is some type of plastic holder that holds two batteries together. Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
Posted on Dec 01, 2010
  • 6 Answers
SOURCE: I have searched the web
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work (be able to be charged using the cradle) in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries.
Lack of bass on MDR-XB600
Impedance of the phone should match with the audio system.Then only we get super audio quality.
Please check up.
Feb 13, 2014 | Sony MDR-XB600 Extra-Bass Stereo...
I have bought a pair of Sony wireless MDR-RF810RK, and after five to ten minutes of listening ,the transmission fails and the light switches off. If I switch on again it recommences for some...
Hello!
I must inform you that most of the wireless headphones has an automatic shut-off which puts it in stand-by when there is no sound going in to it. Or if the sounds in your device is too quiet the headphones will think you have finished using it.
What you need to do is increase the volume setting of your device. And turn the volume control on the headphones down then as well - assuming that your headphone base unit is connected to the headphone socket of your device.
ALPUG
If this will help, please give this answer some ratings!
Feb 24, 2011 | Sony MDR-RF970RK Headphones
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
Sony MDR-EX36V Stereo Headphones - No Bass or Stereo Sound
for the bass check your eq on your player (make sure it not off or default)..for the stereo effect you might have yanked the wire a bit from the ear piece or even the plug piece to cause the non stereo ....earbuds get caught on a lot things and we just keep movin and doin until its to late...
May 28, 2010 | Sony Bud Style Headphones
Sony MDR-XB700 broken left ear
You could try to use a player with a stereo balance and adjust that, but in reality you need new headphones. Sonys have very comfortable and flexible cabling but the downside is that they wear out easily.
Mar 13, 2010 | Sony Audio Players & Recorders
Headphones gone quiet
Well, I think you've just blown them. I need more details...what music were you listening to? How loud? Etc.
Jun 08, 2008 | Sennheiser CX55 Consumer Headphones
Can these be hooked up so you can hear the tv external speakers as well?
I have the headset running through an amplifier so my wife can listen at her volume level and I can adjust the headset volume for myself. The volume dial on the amp is set to zero; but the audio output jacks still provide plenty of volume to the headset. You can get a reasonable amplified for $100 or less
May 27, 2008 | Sony MDR-RF970RK Headphones
Sony 7506 Headphone Replacement Drivers
One of the channels on my MDR-7506 gets a little fuzzy in the bass intermittently, too. It's got a sound like there's just some hair or something in there; it doesn't sound like an electrical noise. This is not a very professional solution, but I found the problem goes away if I give it a good tap with my finger, right on the driver (the part that faces your ear). No need to remove the covers or anything. The delicate parts of the driver are well protected from something as blunt as your finger. As long as you're not pounding on it or jamming things into it, there's no danger of doing more damage. In mine the symptom is a minor inconvenience, so I'm not inclined to buy new ones yet. I heard that special ordering each driver from Sony costs almost as much as a whole new unit, so repair isn't cost-effective if the driver really needs to be replaced.
As for replacement, well, for durable, multi-purpose headphones with great range at a reasonable price, the MDR-7506 can't be beat. Some people say they think the high end is too bright on these, and the low as well, but if you've got normal patterns of hearing loss, you probably need the slight boosts, IMHO. Just don't switch to anything else without testing them out with your own music first; if you go shopping for something different, go to a store that lets you test the phones and bring some CDs and/or a portable player with music you're familiar with.
May 19, 2008 | Sony MDR-7506 Professional Headphones
Sony MDR-RF810 wireless headset SONY Logo
327 people viewed this question
Top Sony Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
basssplayer
Level 1 Expert
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
