Question about Casio Parts Cash Register PC Desktop
Can the EJ data be exported to excel in a readable format?
How do I find and edit this data.
It was a sharp register. I was able to download the manual from the web.
Posted on Jan 22, 2009
How can i export the data tally to excel
There are 2 ways to do it..
Step 1
You can export as text and import it back to excel using the text file you created.
Or
You can select HTML and give the file name as eg-XYZ.xls
Step 2
You can export all reports and statements. For this a separate export button is provided in right hand button bar. To do this go to any report e.g. day book you to export or any statement e.g. balance sheet. You would see export button on top right hand side on button bar. Press it and a screen would pop up with export related options.
The first option is format of data to be exported namely ASCII, HTML, SDF, and XML. Which ever application you are importing this data in would decide in which format you should export the data.
For statements like balance sheets and trial balance which we use to send and import file in word and excel etc. HTML format is good. We need minimum formatting in this format while using it in MS Word and MS Excel.
certain applications accept continuous data where we have defined field length. Then ASCII format is better.
For application which accept SDF and XML format these formats can be chosen.
Give a file name and the exported file is saved in the parent Tally directory on your computer. You can now use that file to import its contents into another program, send it as it is (say if it is HTML file) to a colleague or view it using a browser.
Step 3
Consider exporting day-book.Go to day book press export button or use shot cut key Alt+E. Exporting screen will displayed.
Press Back space on your keyboard. And select Format as ASCII (comma delimited). Now give output File Name as Daybook.csv, now select some other option you want to export from the bottom of the screen.
Press enter to accept screen. Day book is exported in to tally program folder. Check program folder for file daybook.csv,
Double click on it, the file will open in excel program. If you want it in excel work sheet file, use the option Saveas, and save it in Microsoft excel workbook (*.xls) format.
Hope this is helpful. Let us know if the issue is resolved.
*Rating and Comments are invited for this solution
Nov 24, 2010 | Tally T2245 Matrix Printer
I HOW I EXPORT TALLY 7.2 DATA IN EXCEL FORMAT
Step 1
Or
Step 2
Step 3
Nov 10, 2010 | Tally T2245 Matrix Printer
Export tally data to excel
tally data to excel converting . i have some data export to excel but no excel formating you have some tally data to excel spred sheet software
Aug 27, 2009 | Tally T2245 Matrix Printer
Add a excel format in tally
Sir,
What to Export ?
Tally has a facility to export its data to other applications like spreadsheets, word processing software and other database software. Export of data is provided mainly for summaries and statement reports like Trial Balance, Stock Summary, etc. You can export it to another company using Tally that will import it directly.
How to Export?
Thanks
Good Luck
Aug 14, 2009 | Adaptec Computers & Internet
How can i export Tally Data to Excel
when u give the print commant u get an export button on the right side. Press that button and then then selest the rewuired format. XML is the genaralised format used these days. Then import the data in tally
Apr 30, 2009 | Tally T2245 Matrix Printer
How to convert Excel data in to Tally a accounting software
Select ASCII. Give output file name Eg:d:/exp Open the file using EXcel.Select Delimite  nexxt comma finish.Export is completed or You can do 2 things , first you could export as text and import it back to excel using the text file you created , secondly you can select HTML and give the file name as eg-XYZ.xls
or Try using UDIMagic Free Edition to Export Tally data. Download it fromhttp://www.rtslink.com/images/udimagic-free-edition-setup.zip
Jan 06, 2009 | Microsoft Excel for PC
How do i export data from excell to myob i have the 2003 microsof
You are going to do the opposite.
Not exporting from excell to myob but to import data of excell from myob)
You might need to save your excell data as an older office 2000 or office 97 version or even comma or tab sepperated file so myob could read it, it depends on your myob version and if it possible.
Thank you for using agadycom.
Nov 27, 2008 | Microsoft Windows XP Home Edition
How can i export tally data to excel format?
Export to Excel With new release now you would get one more options while exporting data. One added format option is Excel format. excelexport.jpgIf you export in this format then file would be saved in xls format. More over if you put Excel formating option to Yes then tally would automatically format the data in presentable format. Tally would automatically bold the headlines and main fields for you and format data in a good way. Take a look at excel snapshot of balance sheet exported from Tally.
excelexport2.jpgThe special thing here is that you can do the calculation on any amount figure or any row or column, which was earlier not possible. The only drawback which i could find was that amount figures are not right aligned which is must for numbers for easy calculation, although you can do it by selecting the amount figures and putting them right aligned.
Feb 27, 2008 | Computers & Internet
Export tally data to excel format
Jan 02, 2008 | Tally T2245 Matrix Printer
Casio Parts Cash Register PC Desktop Logo
95 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
