Question about Radio Communications
Not able to pair Sennheiser MM 500-X Bluetooth headphones.
Hello, I recently purchased the Sennheiser MM 500-X Bluetooth headphones. I initially was able to pair the headphones to my Ipod Touch. I then tried to pair the headphones to the bluetooth adapter on my laptop but was unsuccessful. I no longer able to pair the heaphones to ANY device including my Ipod. Upon reading the user manual I beleived the headphones are stuck in reset mode. The headphones main button goes automatically into flashing alternating blue & red. What should I do to get my headphones to pair again?
How do I pair my phone and iPod at the same time?
I don't think you can pair two devices at the same time. You will have to pair one at a time . On the phone go to connections and bluetooth , switch bluetooth on and make sure it is visible. Press scan for devices .your headphones should be shown in list if they are set to visable .press pair and a option to put in a 4 digit code willcome up type in a code and put same code in the headphones and press pair these devices. Do the same with the ipod but type in a different code and put code for ipod in headphones pair devices . You should be able to listen to either one
Jan 21, 2015 | Cell Phones
No power sennheiser rs120
Probably a defective item, Try for a return.
Oct 13, 2014 | Sennheiser RS 120 Consumer Headphones
Flashing blue light
1. turn it off2. hold centre button until blinking blue and red3. briefly press volume down4. turn it off= fixed :)
From Sennheiser UK:http://www.sennheiser.co.uk/uk/home_en.nsf/root/contact_menu_technical-question_telephone_headsets_faqs_mm400_series_bluelight
Jun 19, 2012 | Sennheiser MM 550 Wireless Headphones
I have bluetooth headset MM100 but Windows 7 cannot locate drivers for it.
This is a strange question I will explain.
The MM100 is working according the A2DP (bluetooth) protocol.
So windows 7 can not find your sennheiser drivers because there are none.
Windows 7 needs the driver for your bluetooth card. This is either integrated in your computer or you are using a USB dongle.
Through the bluetooth software within windows 7 or a alternate program provided with your bluetooth card you can look for your sennheiser. This is colled pairing.
There are thousends of methods to pair so read the manual of your computer (bluetoothcard or dongle) aswell as the MM100.
Good Luck
Aug 03, 2011 | Sennheiser Sennhesier MM 100 Bluetooth...
One side of the headphones does not give sound consistently... if I jiggle the connector to the ipod and hold it at a certain angel I can get sound to both headphones, but I'd like to find a real...
Well the good news is, it's not your ipod.. It's the wiring inside of the headphones. I suggest that you either return them for a new pair, or buy a new pair.
May 20, 2011 | Sennheiser PXC 250 Consumer Headphones
I have a problem, I recently bought new headphones for my iPod Touch and apparently I tried them and hear one side of my headphones. This also happened to my last pair of headphones. I don't know if it's...
It's more then likely the haedphone jack in the iTouch that has the problem... nit the headphones
Try the headphones on another device
Jan 08, 2011 | Vacuums
My Sennheiser RS 110 headphones won't work. I followed the installation directions but all I get is static. What else can I do?
First thing is you need to have a signal going to the headphones for them to work.
If you are getting a signal the green light should be lit.
If only the red lamp is lit the headphones are not getting a signal.
If hooked into a television you should have them plugged into a Fixed Output not variable output..
If you only have a variable output then you must turn the speakers off on the television and then turn the volume up on the TV in order to send a signal to the headphones.
If you are using a amplifier make sure you are using the correct output. Tape Monitors generally will not work as this output is not amplified.
Lastly try using an rca to headphone adapter and plug them into a headphone jack.
Don
Jan 02, 2011 | Sennheiser RS 120 Consumer Headphones
Is BW 900 Sennheiser compatible with Windows 7?
according to Sennheiser, it depends on the compatibility of the usb device driver of your bluetooth adapter in Win7 (it is NOT a BW900 problem in their opinion)
as I understand it, you have therefore to by a new adapter and see whether it works with the BW900. Take the device AND your computer to the shop and have them install and pair
Sep 06, 2010 | Sennheiser BW900 Bluetooth Headset
Radio Communications Logo
921 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
