Rotel rcx 400 stereo system 1981 model
Blown fuse stopped everything working. after strip down , found snapped belt had wrapped around motor on cassette drive causing jam and fuse to blow. replaced fuse,now require new belt and diagram of how to replace it. (sentimental value for my mother , otherwise i would purchase new.)
  • 20 Answers
SOURCE: Receiver fuse continuosly blows when replaced and powered up
When a fuse blows it indicates that too much current is flowing. This melts the wire in the fuse.
What is actually damaged is hard to say, remove all the cables and test. If the fuse still blows take the unit in for service.
I doubt that a resistor has died, more likely something has created a direct short. It could be a power supply issue, or an issue with the amplifiers.
Ask for a quote first if it is out of Warranty.
Posted on Apr 03, 2008
SOURCE: Kenwood AR 404 burning w/ open flame.
You are literally playing with fire. Obviously the unit is in dire need of service! Please, take unit in for check out by a pro/tech
Posted on Apr 27, 2008
  • 4234 Answers
SOURCE: Kenwood KR-A4070 blowing 5a 125v fuses
I am guessing that the ceramic resistor is close to the output transistors. I would also guess that one or more of the output transistors has shorted. This causes a high current draw that is blowing the fuse. You could also have a power supply problem. The ceramic resistor is a .22ohm dual emitter resistor that is used in the output stage. The transistors located close by are probably shorted and should be replaced. Start there and let us know what happens once the transistors and the resistor are changed.
Dan
Posted on Oct 10, 2008
SOURCE: teac a 303 cassette deck
Posted on Dec 05, 2008
  • 4 Answers
SOURCE: much loved old J.V.C. unit
try turning it upside down and pluging in and out while turning it on.
Posted on Dec 19, 2008
Hoover carpet cleaner brushes wont spin
First i would be checking for a mechanical restriction stopping the brushes from spinning like hair or similar wrapped around the brushes and jamming them, if all is clear it could be a belt broken or slipping, a stripped gear or an electrical fault, depends on what type of drive system the brushes on your particular vacuume cleaner uses. Hope this is helpful.
Aug 17, 2017 | Hoover Vacuums
My reebok edge stopped working and tripped my red on mains, belt won't drive although it goes up and down, found fuse on board inside which is glass and was very black, broke getting out can i get...
I would say the blown fuse was definitely "a" problem but not necessarily THE problem. Something caused the fuse to blow and it is likely with the belt drive system as the lift was still working. Look for burned or shorted places on the PCB and check the motor. You will definitely need another fuse - get 3 or 4!
There are several motor troubleshooting vids on utube. If this one isn't helpful, try some others.
Jan 11, 2015 | Reebok Exercise & Fitness
My brush stop working
Barring any electrical failure or loose plug the most common cause for the vacuum brush to stop turning is belt clogged with debris or string.
Unplug the unit and check the brush for string or debris (Hair) wrapped around the pully on either end. Clear this and check the belt to make sure it has not broken, stripped or simply slipped off. Usually the bottom plate is held on with just a few screws. Easy to remove and check Belt slipped off or stripped replace. Belt slipped off you can sometimes put back on and be vacuuming in no time.
Anything wrapped around the spindle a pair of needle nose pliers comes in real handy here. If you have snagged a rug, sheet or sock etc.. check the manual for a reset button. Some vacuums have this and all it takes is clearing the chute then resetting the switch. Good luck hope this helps!
Apr 03, 2014 | Vacuums
I have a GE Minisplit model AE1C12DBH1 and the fan motor does not work, I would like to know where I can get it or a replacement part?
check for tight connection of motor in pcb and in strip, check for capacitor , if everything found ok then it means motor get blown off , replace it
Oct 12, 2013 | GE Quiet-Aire Ductless Mini Split System...
Blown fuse but appliance still works
There may be a short AROUND the fuse. Kinda rare but it does happen.
Nov 22, 2017 | Beko Wm & Wma Models Washing Machine Motor...
Lights on istrument cluster and heat/ac control went out on 2002 1500 silverado ls
Hi William, I'm glad to help!
William, after working in the automotive field for over 40 years I can tell you that most electrical problems that occur after someone has installed a stereo system comes from a fuse blown somewhere in the system. Take a test light and check all the fuses first if you find one blown replace it and see if everything starts working again. If everything starts working again then your fine, BUT, if its still not working then don't stop there because more then one fuse may have been blown keep going until all fuses have been checked. Hope this helps and have an awesome day William.
Feb 17, 2013 | 2003 Chevrolet Silverado 1500
Dryer has power. control lights working. when you press the start button the only sound is a humming noise. will not start.
Check your drive belt which is located around the outside of the drum. The "hummmm" you hear sounds like the motor running. Normaly this motor provides the power to the belt which surrounds the outer surface of the drum (where u put the cloths)........ the belt wraps around the outside of the drum, then around a small pully mounted on the shaft of an electrical motor normally located just below the drum on the inside of the outer enclosure. This motor will be mounted to the the dryer's frame by a mounting plate. This motor mounting plate will pivot (like a hinge)..... it will also have an extension spring hooked to it which provides tension to the drive belt when properly looped around the pulley on the drive motor. When the belt breaks or snaps....... the drum stops spinning..... however the drive motor still runs. Thats the noise you hear! Diss-assemble outer sheet metal providing access to drive belt and replace with correct belt recommended for your model dryer. Caution should be used during repair........ ALWAYS UNPLUG POWER CORD PRIOR TO SERVICING ALL/ANY APPLIANCE's !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
May 14, 2011 | Frigidaire AEQ8000FG Dryer
I have a Porter Cable 503 belt sander that heats up to the point that I can't touch it and have to stop using it to let it cool. I have been using this model for years, have relied on it exclusively, and...
I have a black and decker BR300 that I've had the same problem with.I don't know if yours is caused by the same things but what I found was that the vacumn system on mine was not sealed up good enough and too much dust was getting around motor cooling fins. Unfortunatly on mine by the time I figured this out it had frayed the drive belt which caused some small strands to wrap around drive gears and mostly trashed the motor. Hope this is of some help to you. Thanks
Nov 03, 2010 | Porter Cable Tools & Hardware - Others
I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Jul 24, 2010 | Crosley CR248 Turntable
RCX 400 Serial port connection failure
If you are sure it is not the cable--- and the serial port NUMBER is correct-- then time to send it back to Meade for repairs. ARE YOU SURE that you have set the SOFTWARE to the proper port number?
Jun 12, 2009 | Meade RCX-400 Telescope
165 people viewed this question
 Grubhead
Grubhead
