Question about Hunter (25417) Ceiling Fan
It only work on the low speed - Hunter (25417) Ceiling Fan
    Genius:
  • Hunter Master
  • 1,617 Answers
Most likely the receiver is bad. You can order a new one at 1-888-830-1326.
Posted on Jan 24, 2013
Why won't one of the spa motors start at low speed?
bad two speed relay on that motor
Oct 10, 2015 | Pool & Spa
My pump will only work on speed 2, however ...it will only heat up on speed 1, so the hot tub is cold. Any idea??
Spas that are connected with the supply voltage of 120, will only heat on low speed.It is designed that way, so that when the motor switches to high-speed, heater will turn off, so that the current draw will not overload a common 15 a outlet.
by the description of your question, I would venture a guess, that the relay for low-speed, located on the circuitboard, has failed.
if I was the technician on site, doing a troubleshoot, I would want to know if the motor it's self is operational, on both speeds?
So I would bring in an alternate source of power, and test each speed individually, confirming whether or not low-speed actually does work?If it does not, then you know it is the low-speed side of the pump motor that has failed. But if low speed does work with alternate power, then you know it is in the controlling circuit.
Tech Support for Balboa Water Group
1-714-384-0384
Jun 08, 2015 | Pool & Spa
Broan range hood QP130ssC only works on low speed no high speed
Sounds like the switch, a bad resistor would work on high because the high setting bypasses the resistor, and if it works on low, it's not the motor !
Jan 04, 2015 | Cars & Trucks
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
Low speed on heater fan does not work. All other
You will need to inspect and test the speed control resister and the speed control knob first. What have you done so far?
Apr 22, 2010 | 2002 Chevrolet Silverado
1970's 10 speed - Low speeds are barely working.
Replace the motor with a similar size and voltage. It should say on the motor what size it is.. Take the gear off and save it for new motor.
Aug 17, 2009 | Food Mixers
I have a 2 speed spa motor (K48m2a4) that stopped working at low speed. going to high speed only has circulating power.
Either the low speed circuit is defective or a relay is inoperative. If you feel confident , you could switch the low and high speed leads on terminal plate. The high speed jet button would activate low speed on pump if motor is good.
Aug 01, 2009 | Pool & Spa
Hunter (25417) Ceiling Fan Logo
18 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
