Question about Kohler Home
San Martine #K-3435-AA, K-3435-AB, K3435-AC, K-3435-DC toilet
FLUSH VALVE, FILL VALVE , FLAPPER
picatudo
  • 239 Answers
SOURCE: Toilet fills up slowly
buy a universal fill valve and replace it
Posted on Jan 03, 2009
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Posted on Jan 10, 2009
kachbibi1
  • 979 Answers
SOURCE: Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Posted on Jan 28, 2009
gypsycat00
  • 224 Answers
SOURCE: toto toilet, flapper doesn't stay up long enough to flush
One of two things is the problem. First, make sure that you have a tight chain with little slack. If there's too much slack, the flapper won't catch in the passing air to stay up. Second, the flapper is not correct for that style of toilet. You might want to look into purchasing a new Kolby filter that has a removeable cone in the center. Move that cone to 12 o'clock to allow the maximum amount of water to run through the flush valve. If the flapper you have now is flat, it needs to have a cone in the center on the underside.
Posted on Jul 10, 2009
  • 3600 Answers
SOURCE: Toto fill valve continual problem, new toilet
There are cheep fill valves and ther better built fill valves, so make sure you buy aa quality fill valve. Also buy a pressuer gauge at ahard ware store and check water pressure level at a faucet outlet. Screw gauge onto water fauct leave a little room for air to escape when water is drippng out tighten the hose bib on the gage turn on the faucet and read the pressure. If it's more than 50 PSI you need to lower the water pressuer. I need to know if your on a, on site underground well,or are on city water to tell you what you need to do to to fix this problem. If there is one. thanks for using Fix-ya if you want more info post here.
Avid101
Posted on Aug 24, 2009
Toilet is running
The most common reason for a toilet to continue to run is a problem with either the flapper or the entire flush valve itself. The water is slowly draining so the fill valve keeps running.
The flapper is the least expensive and easiest solution, so start their. It's usually around $5. If that doesn't solve the problem, I would purchase a flush valve kit, around $20, and replace your flush valve.
*Note: If you have to replace the flush valve, you have to take your toilet apart. Start with the flapper.
Feb 27, 2015 | Home
It takes a long time to fill the tank
There could be partial blockage of the water supply line causing a slow fill.
Feb 20, 2014 | Kohler Cimarron Comfort Height elongated...
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
We have a san raphael one piece toilet, and it sounds like the water is running at intervals. Sounds like there is problem with water level. What can I do to correct this problem? John
Sounds like the flapper is leaking water out of the tank. The flapper is the rubber valve that comes up and down every time you pull the flush lever. It is located in the tank at the bottom in the center. Very cheap part to replace.. Just turn the water off to the stool, take the top of the tank off, hold the flush lever down until all the water is out of the tank, reach in to the tank, disconnect the flush chain from the flapper, and disconnect the flapper arms holding to the stem. You can buy a flapper at any hardware store even at wal mart. Hope this helps.
Jun 25, 2011 | Kohler - Toilet - One-piece - San Raphael...
My toilet keeps running. I tried to adjust the float with a phillips but that did not work. There is slight leaking into the chamber over the top.
If there is a continual leak in to the toilet bowl you will likely need to replace the flush valve or the toilet flapper.
As a first step try try cleaning the sealing surface of the flush valve to se if the flapper will seat and make a seal.
If this does not work and the flapper is visibly detioriated and breaking down shut off the water supply, remove the toilet flapper and visit your local plumbing supply store to purchase a suitable replacement. Install the new flapper, turn on water supply.
These illustrated instruictions may also assist:
http://www.danco.com/HowTo/How-To-Replace-a-Toilet-Flapper
Although less likely, if the sealing surface of the flush valve is damaged or detioriated proceed with replacement of the flush valve. Again turn off water supply and follow the instructions set out here:
http://www.danco.com/HowTo/How-To-Replace-a-Flush-Valve
If there is not a leak in to the toilet bowl and the water flow does not shut off completely, then water is flowing through the fill valve and the overflow pipe and you may need to adjust the float and float rod to allow clsoure of the fill valve. See here:
http://www.danco.com/HowTo/How-To-Replace-a-Float-and-Float-Rod
Mar 09, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
Water continue to drip just a little after fill valve stops
Check the little tube the goes from the fill valve into the overflow tube. You NEED to have a good arch in the tube to prevent back siphon from the tank. If that doesn't work then check to make sure the flush valve flapper is completely seated without any of its port showing. If you see the slightest amount of the flush port then you need to replace the flapper. AS well as make sure none of the chain is getting siphoned into the port preventing the flush valve flapper from completely seating.
Mar 20, 2010 | Toto Toilets ST784S 12 Sedona Beige...
Toilet keeps running even when manually lifting floater to max
check handle to ensure no tension is on the flapper chain when not being flushed. check flapper to ensure positive seal to flush valve. check water level to ensure not overflowing into flow valve. if that's the case, lower water height.
then if still doesn't work, change flapper,
all else fails, change flush valve.
good luck,
steve
Oct 03, 2009 | Kohler Toilet - One Piece with Ingenium...
What is the procedure for replacing the flush valve assy on a san raphael toilet. it is a one piece tank and bowl assy and must install from the inside of the tank. it appears to possibly rotate into place...
If you purchase the flush valve from Kohler, it comes without instruction. Rotation is the key to removal. First note the exact orientation of the assembly before attempting removal. Unhook the flapper chain and remove the flapper. The old assembly does indeed rotate in either direction for removal. I used a counterclockwise motion. (it was a tough turn, don't break the bottom of the bowl where the valve seat is located.) Then install the new foam gasket on the assembly. The new assembly is replaced in the reverse manner. I removed the new flapper from the flush valve for ease of install. You must put significant downward pressure on the flapper seat while rotation is accomplished. Orient the assembly as was the old one. Replace the flapper, connect the chain and observe the flapper for proper opperation.
Oct 03, 2009 | Kohler K-3384-2-0 San Raphael elongated...
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Home Logo
60 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
