Question about Panasonic PT-47WX42 47" Rear Projection Television
Trying to hook up my ps3 to a panasonic cinemavision PT-47WX42 with an hdmi cable through the back component connections. I am getting sound but no picture. Any ideas for help?
Shuttle83
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
  • 4 Answers
SOURCE: Picture doesn't work..Panasonic 47 inch TV PT-47WX42
Dood, if you really needed a new mother board for your TV the biggest problem on your hands would be finding the replacement.  The motherboard is so easy to remove it would make you laugh.  I think it has four clip bridges and four of five screws.  You seperate the clip bridges, take the screws off and maybe take a picture of the cables so you remember where to plug them in and you're done.  Like I said, take a snap shot so you dont forget where to put your cables back in.
Posted on Oct 24, 2007
  • 39 Answers
SOURCE: Picture, No Sound from HDTV Box
CON-YOU'VE DIAGNOSED YOUR OWN REPAIR.GET A NEW CABLE BOX.JOE TV
Posted on Dec 17, 2007
  • 147 Answers
SOURCE: No hdmi input?
You can use the component inputs on your Tv which is almost as good.
Posted on Mar 30, 2009
  • 47 Answers
SOURCE: Can't play my PS3 through the Panasonic TH-42PZ800A
your HDMI output is bad
Posted on Jun 14, 2009
Component to HDMI Converter Problem
Does the TV have a plug connection I think is called DVI. There is a DVI to HDMI adapter that also needs an audio connection on TV to work. Other option is audio and video rca cables. You may also need to change input connection to correct source, as it may not be auto for connection
Jan 03, 2014 | Panasonic PT-47WX42 47" Rear Projection...
480p to 1080i
Your TV should automatically switch to 1080i if the source input is in 1080i format. Also, since your TV does not have HDMI, you must use the component 1 or 2 inputs (using component cables) for 1080i source material. You cannot get 1080i from composite or s-video inputs. You should be able to switch to the component inputs using the remote or the front control panel using TV/Video button.
Sep 02, 2012 | Panasonic PT-47WX42 47" Rear Projection...
Ps3 hook up to panasonic PT-53WX54J
If none of the connections on the set work look for a menu on the unit in the owner manual for the PS3---it may be a selectable setting in that that is causing this problem--also try the PS3 on another set to make sure it is ok.
Jun 15, 2012 | Panasonic PT-53TW53 53" Rear Projection...
Trying to hook up PS3 to Panasonic viera LCD hdtv with HDMI cable and tv is not reading it and has no picture or sound. What may be the problem? Thanks!
hi,
ur ps3's HDMI out is a full hd video (1080p). if u r tv does not support full hd this problem can occur. do one thing. connect the ps3 to any full hd tv and go to its video setup, then down scale its video resolution to 1080i. after that connect the ps3 to ur tv. u will surely get video.
ok
Jan 11, 2011 | Panasonic Viera TC-L32X1 32 in. LCD HDTV
My panasonic projector pt-ae3000u is not seeing my ps3
Should work right away, are selecting the correct HDMI input? (1,2 or 3?)
Do you have a way of checking the cable?
Jan 13, 2010 | Panasonic PT-AE3000U LCD Projector
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
No hdmi input?
Mar 30, 2009 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Im not getting a HD through my component cables
im using my xbox 360 trying to get it to 720P through component cables but i get a black screen with sound although my ps3 is hooked up through HDMI on 720p without a problem
Jul 27, 2008 | Panasonic Televison & Video
Panasonic PT-47WX42 47" Rear Projection Television Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
