Question about Saeco Syntia Espresso Machine & Coffee Maker
Mode Selector Switch stuck open
Mode selector switch stay open can't move back
How do I switch my surround from off to on Harmon avr347
Surround modes are selected using either the front panel controls or the remote.To select a new surround mode from the front panel,first press the Surround Mode Group Selector Button5until the desired major surround mode group such as Dolby,DTS or Logic 7 is selected.Next,press the Surround Mode Selector Button9to choose the specific individual surround mode.
Aug 19, 2014 | Audio Players & Recorders
1998 Chevy Suburban - service 4wd light comes on after running 4x4 for 2 mins
Well it could be the selector switch, but I doubt it.
Generally, the service light means something is not working that the computer controls. Solenoids and valves are a couple of possibilities.
The transfer case is shifted by solenoids commanded by the body computer based on the switch position on the dash.
You should be able to have a shop scan the body computer for trouble codes and proceed from there.
A basic code reader may not access the body computer.
Jul 05, 2012 | 1999 GMC Suburban
Su-c800u pre-amp switching not steady, keep darting from one mode to another and disrupting smooth flow of music
I had the same issue.the contacts on selector switch is dirty.All u need to get a good contact cleaner and spray the selector rod( remove knob first with preamp facing up), the liguid will find leak into selector and clean contacts.
after doing mine, the slector knob feels more solid when turned and does not change input anymore.
Junior
Jan 14, 2012 | Technics Audio Players & Recorders
MY DISTRABUTION DIAL FOR DEF.,VENT, ETC IS IN DEFROST AND WON'T CHANGE. THE DIAL TURNS BUT NOTHING CHANGES. I NEEN SOME ADVICE ON WHAT TO DO TO FIND PROBLEM AND FIX. THANKS GENO
Here is the info. I hope the pictures show up. please rate assistance. thx.
Air distribution within the vehicle is determined by the function selector switch position. Two airflow mode doors are used to direct airflow within the heater core and evaporator core housing. The function selector switch/cable assembly is used to position these airflow mode doors. Refer to Section 412-00 for description and operation of each of the system functions.
Function Selector Cable Assembly
The function selector cable assembly moves the airflow mode doors to the desired position using a 2-sided pull-pull type cable assembly. The function selector controls the cable movement. The end of the cable assembly attaches to the airflow mode door/temperature blend door actuating assembly which transfers the cable movement to the 2 airflow mode doors.
An electrical switch is incorporated into the function selector to notify the A/C switch assembly if DEFROST or FLOOR/DEFROST is selected. When DEFROST or FLOOR/DEFROST is selected, the A/C switch assembly will disable the RECIRC request button and send an A/C request to the powertrain control module (PCM) regardless of the A/C request button indicator ON/OFF status.
SECTION 412-01: Climate Control 2005 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 02/25/2004
Function Selector Switch adobe.gif Printable View (173 KB) Removal and Installation
  1. Remove the 4 bolts and position aside the lower steering column cover.
  1. Remove the function selector knob.
  1. Remove the center instrument panel finish panel.
    • Disconnect the cigar lighter electrical connector.
  1. Detach the function selector switch.
    1. Disconnect the electrical connector.
    1. Remove the screw and detach the function selector switch.
  1. Detach the function selector cable and remove the function selector switch/cable assembly.
  1. To install, reverse the removal procedure.
Aug 04, 2011 | 2005 Ford Focus
Shooting in black and white --i don't know what is the problem --need help
1. Set the Power switch to CAMERA.
2. Set the Mode switch to TAPE. (VP-D353(i)/D354(i)/D355(i) only)
3. Press the MENU button.
4. Move the Menu selector to the left or right to select Camera, then press the Menu selector.
5. Move the Menu selector to the left or right to select Digital Effect, then press the Menu selector.
6. Move the Menu selector to the left or right to select the desired Digital Effect mode, then press the Menu selector.
7. To exit, press the MENU button.
Feb 18, 2011 | Samsung SC-D353 Mini DV Digital Camcorder
A/c blows thru defroster
Sounds like the switch behind the selector is eithe broken, or stuck in that posiition (or internally) is not moving. I suggest pulling the heater/ac selector unit out and checking the levers from the back side.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Oct 02, 2010 | 2001 Mercury Mountaineer
Canon 40D camera On P mode it is - 2 stops I can't find the setting to take it back to 0 and my pictures are underexposed.
When you turn on the camera, there's an option to turn the switch beyond "On", indicated by an angled line. Move your power selector switch there. Then half-trigger a scene and turn the Quick Control dial behind the camera to adjust the Exposure Compensation. Note: Being in "On" mode doesn't enable exposure compensation, leaving the settings stuck at previous.
Apr 19, 2010 | Canon EOS 40D Digital SLR Camera Digital...
Ac controls
selector mode switch is bad
May 24, 2009 | 1998 Chevrolet Astro
My SUV is stuck in the 4X4L mode.
In order to get it to shift in or out of 4 lo the transmission must be in neutral with your foot on the brake and moving less than 5 mph. If it still does't change try tapping the shift motor with a block of wood, it could be stuck
Nov 26, 2008 | 2003 Ford Expedition
Canon powershot a70 take apart help
Useful link: http://f20c.com/stuff/canon/partslist/
Rolf
Jun 23, 2008 | Canon PowerShot A70 Digital Camera
Saeco Syntia Espresso Machine & Coffee Maker Logo
21 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
